10-31-2016
11:08
18:17
10-31-2016
11:08
18:17
Hi there,
I was hoping someone could give me a hand with a problem I had with my Alta.
This morning I was on the treadmill for 35minutes doing HITT.
My Alta recognized I was actively working out since it did record my 35 active minutes.
The problem is that although it did record active minutes it didn’t track mi exercise.
I have no exercises recorded for today!
* Why did this happen?
*How do I fix it now so it shows my active minutes + the exercise I did today
* How can I know how many calories I burnt during these 35 active minutes or during this workout that wasn’t recorded?
Hope someone can give me some insight since I´m a bit confused!
Update: My Alta is set to auto recognize exercise after 10min..
Moderator edit: Format
08-26-2020 19:10
08-26-2020 19:10
Fitbit versa is tracking steps, active minute but not my exercise/calories burned during. I’ve tried everything, logging out, restarting, syncing over and over and nothing. Very frustrated.
08-30-2020 07:17
08-30-2020 07:17
Das Problem habe ich auch... 40 min ellipsenTrainer und nichts wird als Training angezeigt
Best Answer07-20-2021 17:59
07-20-2021 17:59
Has there been a resolution to your problem?
The the threads huge!
If there was could you let me know what it was 😊
Best Answer07-20-2021 18:27
07-20-2021 18:27
Best Answer07-21-2021 18:06
07-21-2021 18:06
I had the same thing happen. I did 2 separate walks today that were recognized with both minutes and auto recognized as walks. Tonight I did a 1 hour Zumba class that was not recognized for the minutes nor the exercise type. I did get the number of steps counted though. Getting frustrated with my Fitbit watch. It’s not being consistent when exercising.
07-22-2021 00:39
07-22-2021 00:39
Thanks for trying to help but It's a new problem. It recognised a 10 minute walk as exercise last week and today it does NOT recognise a 30 minute walk. I suspect a programming change has accidentally broken something; it will probably "magically fix itself" when the developer finds the bug they introduced.
Best Answer07-22-2021 21:30
07-22-2021 21:30
@Njpjean Zumba is not an auto recognized exercise.
You may want to record as a workout, then rename after a sync.
