02-17-2016 04:06 - last edited on 08-20-2020 18:43 by MatthewFitbit
Will the Alta recognise an Elliptical workout? My Flex doesn't.
02-17-2016 07:53
02-17-2016 07:53
Yes, it will recognize an elliptical workout.
02-17-2016 07:53
02-17-2016 07:53
03-15-2016 11:40
03-15-2016 11:40
03-15-2016 12:20
03-15-2016 12:20
@Mssandy033 Alta can use SmartTrack to recognize your elliptical workout - however, that likely requires you to use the type of elliptical machine that involves moving bars for your hands. If your hands are stationary on a bar, there is no way for your device to know that you are working out on an elliptical machine.
In that case, since you are neither moving or taking actual steps, I wouldn't expect the count to be reflective of your activity. It would probably be better to log that activity manually, which will give you a more accurate caloric credit for the activity.
03-15-2016 13:43
03-15-2016 13:43
03-15-2016 15:59 - edited 03-15-2016 17:06
@Mssandy033 wrote:
My elliptical has moving bars yet Smart track cannot pick up on the steps. Please work on fixing this issue as soon as possible. Not being able to register my activity on the elliptical defeats the purpose of wearing a tracker.
Sent from my iPhone
Hi @Mssandy033 - it you are in the default settings for smart tracking you need be using your elliptical for at least 15 minutes (you can change this to as low as 10 minutes). Might try 20 just to make sure the activity registers. Depending on your movement, you may or may not register "steps" while on the elliptical. Since you are not really stepping, the tracker may not register the movement as steps. Similar issue with bike riding.
I hope it works out for you. Let us know.
Scott | Baltimore MD
03-15-2016 21:27
03-15-2016 21:27
03-16-2016 04:51
03-16-2016 04:51
03-16-2016 19:16
03-16-2016 19:16
I am having the same issue with my Alta. I worked out at a medium pace with moving bars for 25 minutes and nothing logged for activity.
03-16-2016 19:28
03-16-2016 19:28
03-17-2016 10:45
03-17-2016 10:45
03-20-2016 11:15
03-20-2016 11:15
03-20-2016 22:04
03-20-2016 22:04
03-21-2016 10:19
03-21-2016 10:19
I experience the same on the eliptical - the eliiptcal says 4600 and Alta says 3000 or less. I don't use the arms on it so I hold the handles - this is very disappointing
04-12-2016 15:18
04-12-2016 15:18
Yes! I can't get my ellptical workouts to register. This is very frustrating since on days I can't walk I do about an hour on the machine. I hate that it does not register. It always worked with my old fitbit one.
04-12-2016 16:04
04-12-2016 16:04
04-13-2016 08:41
04-13-2016 08:41
My alta does not recognize my elliptical workout. I have moving handles. Hand were on them at all times.
04-14-2016 06:41 - edited 04-14-2016 06:43
Apparently not. But according to the specs it should.
04-14-2016 19:53
04-14-2016 19:53
I was bummed too when I realized it didn't track my elliptical workout tonight!
04-14-2016 20:01
04-14-2016 20:01
