03-15-2016
19:44
18:43
03-15-2016
19:44
18:43
08-26-2017 12:21
08-26-2017 12:21
08-28-2017
00:53
06:21
MaginB
08-28-2017
00:53
06:21
MaginB
Hi, welcome to the chat however, I am not certain why I am receiving the question???
Good luck!!
Moderator edit: Format
08-28-2017 02:00
08-28-2017 02:00
Hello fellow Alta users. As previously stated. I am an owner just like the rest of you, therefore your questions should be referred to the company, not me the consumer.
Thanks!
08-31-2017 00:34
08-31-2017 00:34
Hi. I'm having this same problem. Was there a solution for this?
09-14-2017 07:29
09-14-2017 07:29
I have the exact same thing. brand new... set up... wont hold a charge... this is so frustrating... I paid a lot of money... should work better
09-25-2017 03:49
09-25-2017 03:49
Terrible experience. Lost Fitbit flex, purchased new Fitbit Alta. Cannot delete old Fitbit flex account - new Alta cannot set up. Absolutely frustrating. If iPhone had more than step tracking I would use it and return Alta. Great experience with Flex but Alta is awful.
10-20-2017 00:18
10-20-2017 00:18
I tried your method several times and I just keep getting the URL for set-up on my screen, my iPhone doesn't recognize it and I'm totally frustrated. I've had it less than 5 hours. That's not good.
10-20-2017 03:53
10-20-2017 03:53
10-20-2017 16:03
10-20-2017 16:03
Thank you! I had such a busy day and I can't bear to get on with a support person right now. I'll give them a call tomorrow. I'm VERY surprise at how difficult this product is to set up and how many questions there are about using it. It shouldn't be like that.
@Snowfolk wrote:
Call FitBit support. Dont frustrate yourself. They will figure it out or send you a new one. Fitbit support takes forever but they are good. Good Luck
Stacie Hackel Snow
"Today's mighty oak is just yesterday's nut that held its ground."- Anon.
11-10-2017 04:26
11-10-2017 04:26
I've lost my original charger and I don't see anything on this charger to push three times in 8 seconds to try a reset.
11-19-2017 12:52
11-19-2017 12:52
Hi I am having same issue and have tried restarting several times but no luck, will only activate when plugged in. It was working fine on saturday and recorded my sleep but since Sunday morning nothing. very frustrating as i only got it on Saturday. Purchased from a friend who had bought previously but never used it, still new in box. what else can I try?
11-27-2017 19:50
11-27-2017 19:50
Thank you Cindy but nope that pressing button 3 times did not work..
12-09-2017 19:24
12-09-2017 19:24
When I go to charge my Alta, it doesnt charge. When I plugged it in it pulsed. So I changed outlets and plugged it in again, now its completely dead. No combination of different outlets or plugs will work. I dont have a computer to charge it from. It will not even turn on to charge. Ive tried to clean contacts and that doesn't work. I got this in Feb. So its not very old either. It's completely dead.
12-11-2017 05:53
12-11-2017 05:53
thank you - I was having trouble finding the button
12-11-2017 06:19
12-11-2017 06:19
12-18-2017 18:17
12-18-2017 18:17
12-28-2017 16:29
12-28-2017 16:29
Literally having the same problems the Fitbit person said the set up wasn’t completely finished which I actually set up it alone and did alll the steps and I just got it
12-28-2017 16:31
12-28-2017 16:31
I was told to do that and it didn’t work 😒
12-29-2017 04:01
12-29-2017 04:01
12-29-2017 07:29
12-29-2017 07:29
Tried that
