04-11-2016
06:31
18:43
04-11-2016
06:31
18:43
Hello! I purchased an Alta fitbit yesterday and the time is not showing correctly. It is definetly on the right time zone (EST for Florida) but the watch shows the time one hour back. I have tried changing the time zone to something wrong, syncing and changing it back an syncing. I have tried unpairing it and repairing it. I've tried resetting it. Is there anything I can do to fix it?
Thank you,
Julia
04-11-2016 06:54
04-11-2016 06:54
Well, if you have tried all those and nothing works, I would suggest setting it up as a replacement device . This will rerun the set up. That might work. Don't worry! You won't lose any data.
Good luck, and let us know how it goes. Welcome to the Community!
04-19-2016 01:54
04-19-2016 01:54
Hi
I also have the same issue mine is showing GMT when it should be BST. I have set it to london GMT+1 and doesnt seem to work. I have also done all the things suggested without success. If anyone works out how to fix this please let me know.
Cheers
Gary
04:04
07:33
CindyFitbit
04-19-2016
04:04
07:33
CindyFitbit
hi mine was same instead of sync look underneath says check for device update, click on this. having fitbit on charge while doing this good as can drain battery. once update complete sync as normal.
Moderator Edit: Format
Best Answer04-20-2016 07:33
04-20-2016 07:33
Hey @juliagalimidi @colesga @petalrose thanks for joining us here! If the issue persists after trying the steps @juliagalimidi and @Julia_G shared on their posts, I recommend contacting support so they can investigate and evaluate your case. I'm sure they will be glad to assist.
Keep me posted! ![]()
Was this what you were looking for? Vote for it and mark it as an Accepted Solution!
Best Answer04-22-2016 06:21
04-22-2016 06:21
Me too, same problem, the help desk didnt come up solutions that worked either. I am tempted to return mine. Anybody else help???
Best Answer04-24-2016 12:22
04-24-2016 12:22
Hey there @jackiesalta! I'm sorry to hear that, if you have followed all the recommendations on this thread ad well as some directions from support and the issue is not resolved yet, I recommend contacting support once more so they can evaluate your options. Please make sure to explain all the steps you have followed and your previous case number on support.
12:51
13:18
CindyFitbit
04-24-2016
12:51
13:18
CindyFitbit
Hi been back in contact with the support team, received email back- they are going to send a new one. Tried everything to resolve this one. Hope next one is good. Looking Forward : )
Moderator edit: Format
Best Answer04-25-2016 13:19
04-25-2016 13:19
Hey @petalrose thanks for getting back! I'm glad to hear that you will be back on track soon!
Have you checked our Discussions board? There you can share your story, find some fitness tips, recipes and more! Give it a look!
Enjoy y our new Alta and keep the stepping up! ![]()
Best Answer01-11-2017 04:18
01-11-2017 04:18
Can someone explain better how to find the "update"? I don't see it. My fitbit is also perpetually showing the wrong time. I'm looking all over the dashboard and don't see a way to update the software.
Best Answer01-11-2017 13:03
01-11-2017 13:03
where it says set up a new fitbit device/ sync now .....underneath in small it says check for device update/troubleshoot click there its not in the dashboard
Best Answer01-14-2017 05:30
01-14-2017 05:30
Hey there @ChelNy! Hey there if your tracker is not updating is probably not syncing I recommend performing the restart 2 or 3 times in a row. In order to update the firmware check out this great post.
@petalrose Thanks for sharing your knowledge in the Community. 🙂
See you around!
Best Answer01-14-2017 11:09
01-14-2017 11:09
Thanks Mag & Petalrose. I found the place to update the software, and so far it is on the right time and staying there. I appreciate the help.
Best Answer01-17-2017 08:21
01-17-2017 08:21
@ChelNy It's great to hear that you're back on track!
Best Answer08-15-2020 13:18 - edited 08-15-2020 13:19
My was doing this. Right time zone but wrong time. I removed device from my phone and reconnected this solved the issue.
