08-06-2020
17:29
19:01
08-06-2020
17:29
19:01
I disassembled the alta hr myself two weeks ago, because in one day of use, the power was exhausted within four hours after being fully charged.
I searched the Internet for maintenance and sharing videos, bought a new battery with a domestic battery manufacturer, and started to change it myself.
When I change the battery, I can fully charge the battery to 100%, but the battery status cannot be restored to the previous seven days of use.
The restart and repeated charging and discharging I tried can only take up to six hours, which does not seem to be the state of the new battery.
Original battery model : 310919 40mAH
Replaced battery model : 301020 50mAH
The volume is a little bigger, but it can be put in the original position. I am still experimenting with the battery problem.......
08-06-2020 17:45
08-06-2020 17:45
Hi @Cliff.Lee so you replaced the battery and only get six hours of use before needing to recharge?
Best Answer08-06-2020 20:57 - edited 08-06-2020 20:58
It takes 3 hours to fully charge a new battery, and it only takes 6 hours to go from 100% usage to 5%.
I ran the test again in the morning, and after using it for an hour after being fully charged, the battery power dropped by 20%.
Best Answer08-06-2020 21:00
08-06-2020 21:00
Not sure it was worth all the work you did to change the battery, but a good experience, I'm sure.
