05-14-2016
		10:25
		18:17
		05-14-2016
		10:25
		18:17
Hello,
Trying to connect by brand new fitbit Alta to my phone, plugged into the computer, bluetooth is on, it keeps saying "We found your tracker! Connecting ot Tracker..." and then nothing happens. I've restarted my phone, restarted the Alta. I've deleted the app and reinstalled it. I've removed the tracker from my app and currently trying to set it up again. Is anyone else having this problem?
05-14-2016 11:54
05-14-2016 11:54
I am having the same issue. Getting really frustrated!
05-17-2016 07:38
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              05-17-2016 07:38
@MISRNA @ninimorris A warm welcome to our Fitbit Community! So sorry to hear about the setup issues you have experienced with your Alta trackers. If you @ninimorris my friend, have tried what @MISRNA mentioned, such as restarting your phone, your Alta re-installed the app, then my best advice for both of you is to contact our Customer Support team so they can investigate further and get you back on track.
Keep me posted on the outcome my friends and I'll be around! ![]()
08-26-2016 17:19
08-26-2016 17:19
Hello MISRNA,
Did you find any solution to your problem?
Thanks,
Peeyush
 Best Answer08-26-2016 17:59
08-26-2016 17:59
I figured it out myself !
In addition to steps mentioned in post above, delete pairing information of alta device from phone Bluetooth settings before attempting to connect the device. It works, all the data got restored and its working fine now.
hth
-Peeyush
08-29-2016 18:13
                                          Community Moderator Alumni are previous members of the Moderation Team, which ensures conversations are friendly, factual, and on-topic. Moderators are here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              08-29-2016 18:13
Welcome to the Fitbit Community! It's great to have you here @PeeyushNaidu! Thanks for sharing the troubleshooting steps you took to solve the issue. This can be helpful to other users that may experience the same.
Thanks for posting and I hope to see you around more often! 🙂
01-13-2017 11:18
01-13-2017 11:18
I am having the same problem. I have updated my iphone 5s software, deleted and reinstalled the app, turned bluetooth on and off, deleted my previous bluetooth device, checked the charge on my fitbit, turned my phone on and off and have been trying all day. Getting really fed up it still says 'We found your tracker, connecting to tracker' but just constantly buffers. Any other ideas? Thanks
01-13-2017 18:12
                              01-13-2017 18:12
Thanks for stopping by @nikkigardi! This sounds odd. Please check if your mobile device isn't managing other Bluetooth connections. Also, double check if you use more than one Bluetooth phone, tablet, or computer to sync, the other one isn't nearby (or has Bluetooth disabled).
Then, try these steps:
If your tracker won't setup after the restart, try setting your tracker on a different mobile device or computer.
I hope this helps, keep me posted! 😉
01-14-2017 04:08
01-14-2017 04:08
01-16-2017 04:41
                              01-16-2017 04:41
@nikkigardi Thanks for getting back! Since you also tried connecting your Alta with your computer and had no success, I recommend getting in touch with our Support department since they'll be happy to review your case and get you back on track.
Let me know how it goes my friend! ![]()
07-16-2017 09:12
07-16-2017 09:12
Thank you. Disconnecting from bluetooth was the key. Doesn't explain why I had it connected for a week and it just stopped on it's own causing the reconnect issues
07-17-2017 07:12
                              07-17-2017 07:12
@Lockwendy I'm so glad to hear that your tracker is syncing properly now! Thanks for keeping the update here. Regarding your inquiry, the connection issue might've be caused due to several Bluetooth devices near. However, if the issue happens again, let me know.
I'll be around if more assistance is needed my friend! ![]()
 Best Answer08-11-2017 09:05
08-11-2017 09:05
My tracker AND my husband's trackers BOTH just started doing this. The the tracker can be found, but cannot connect. Have tried restarting the android device, have also tried on ipad and iphone. software is up to date. reset the flex. nothing is working. what else can we try?
08-11-2017 17:36
                              08-11-2017 17:36
Hey there @katycot! This sounds odd. Please double check that you are restarting your Flex by following these steps:
Then, try setting your tracker up as suggested in this post.
Keep me posted! 🙂
08-11-2017 18:22
08-11-2017 18:22
08-11-2017 18:38
08-11-2017 18:38
Hi,
Did you try by first deleting the Fitbit device from your phone paired Bluetooth device list.
-peeyush
08-11-2017 18:42
08-11-2017 18:46
08-11-2017 18:46
You could also try by uninstalling the phone app. Your data is stored in Fitbit server which means all will be retrieved when you login after fresh installation.
-peeyush
 Best Answer08-11-2017 18:51
08-11-2017 18:51
08-11-2017 19:44
                              08-11-2017 19:44
Awesome tips @PeeyushNaidu.
 Thanks for the update @katycot! To better assist you I have a couple of questions:
Also, notice that it’s best to keep your husband's tracker at least 10 feet away to avoid any interference while setting up.
I look forward for your reply! 🙂
