01-17-2018 11:42 - last edited on 08-20-2020 20:08 by MatthewFitbit
I record my running data on www.mapmyrun.com but i'm unsure how to link fitbit with this
01-18-2018 09:21
01-18-2018 09:21
A warm welcome to the Community Forums @davidhampstead! 😄
I can definitely help you with this.
You can set up MapMyRun to automatically import your steps from your Fitbit tracker. To connect the accounts, please do the following:
Provided your tracker has synced to Fitbit, logging into MapMyRun will automatically import your subsequent step history.
Hope this helps. Anything else you may need, I'm always around!
03-07-2018 09:45
03-07-2018 09:45
How do I connect these two apps?
03-10-2018 11:00
03-10-2018 11:00
Welcome to the Forums @davidhampstead! Have you tried the kind suggestion by @FerdinandFitbit from the post above? Or, you can take a look at the help article How do I connect my Fitbit account with another app?
I hope this helps, keep me posted! 🙂
03-13-2018 13:04
03-13-2018 13:04
I realize that I seem pretty unintelligent...but where is the improve tab?
03-14-2018 05:40
03-14-2018 05:40
Hi @NKContreras, thanks for getting back! 🙂
I'm sorry, but, what are you referring to with the "Improve tab"? You only need to go to the Apps section on your settings but you need to make sure you're doing this on a computer on your browser. Go to fitbit.com/user/profile/apps or simply click here and follow the instructions above.
Hope this helps and please let us know if you need anything else!
04-12-2018 13:37
04-12-2018 13:37
I walked today and the map showed my route, steps etc. (I pushed finish because I finished)! This afternoon I wanted to walk again and couldn't pull up the map to show my route or even add it to the original one. Is there a better way to do this or should I download a different app that would sync with the fitbit? Thanks for any info. (I am new to all of this so am just learning).
04-12-2018 14:51 - last edited on 04-13-2018 13:33 by LucyAP
I hate to be a downer, but I was never able to get my stuff to link,
satisfactorily. Map My Run & my Fitbit both show a dramatic difference
with steps & calories burned but I use them both to just have a decent idea
of what I've done, on a daily basis. I use my Fitbit to keep up with my
daily steps but I actually log my workouts with Map My Run. I'm sorry-I
wish I were more help!
Good luck-
~Nancy
Moderator edit: personal info
05-21-2018 02:12
05-21-2018 02:12
This is what I’m seeing as well. I’ve been doing road biking since I got my Fitbit last week and it’s always behind a mile or two on the distance. Map My Fitness tracks it reliably because other bikers have clocked that distance at the same as MMF is doing. I just want the two apps to hold hands and be friends (lol) so that I’ve got as much accuracy as possible. So I use MMF when I’m riding but Fitbit tracks literally anything else. I found an article that said how to connect them and when I go ride in a bit I’ll see how it works out.
05-25-2018 09:53
05-25-2018 09:53
Nancy,
I'm getting the same issue. My Fitbit is off by a quarter of a mile in distance - and for some reason today I went for an hour and it had the time as 38 minutes! WTH? I have no idea what is going on with the Fitbit HR but it just started about three weeks ago - up until then everything matched well. Very frustrating as I don't want to always run with my phone to track my distance! But right now I don't trust my Fitbit. From other threads on the forum, it seems a lot of people are having issues with this - particularly the Fitbit Charge
06-08-2018 11:51
06-08-2018 11:51
I've managed to connect mapmyrun and fitbit. It says its synced but nothing from fitbit seems to be on mapmyrun. And I don't seem to have an import button on mapmyrun dashboard
06-15-2018 20:10
06-15-2018 20:10
My Fitbit is linked to Map My Run but it won’t upload any data. Suggestions?
07-11-2018 01:54
07-11-2018 01:54
Mine also keeps coming up with'sync error' , every time I go to sync it. So same problem. My Fitbit data will not go across to mapmyrun???
Any other ways to go about this?
07-11-2018 07:08 - last edited on 11-08-2019 13:30 by LiliyaFitbit
None that I’ve found
07-18-2018 18:58
07-18-2018 18:58
I don’t see the Import Workouts and my Fitbit activity isn’t showing up in MapMyWalk.
07-25-2018 09:18
07-25-2018 09:18
I’m having trouble importing my runs, I’ve just done 5K and it’s logged on my Fitbit app but not on my MapMyRun, however I have already connected my Fitbit to my MapMyRun. Any help would be appreciated
07-26-2018 12:28
07-26-2018 12:28
07-26-2018 15:23
07-26-2018 15:23
09-13-2018 19:58
09-13-2018 19:58
HI, it does not show when viewing app on phone. Go on their desktop website and login to see more functions and options.
12-24-2018 00:14
12-24-2018 00:14
May I know where do I find the import button?
