01-19-2018 18:31 - last edited on 08-20-2020 20:08 by MatthewFitbit
My screen has cracked - without me knocking it on anything. It's less than a year old. How to I get a new screen?
01-19-2018 19:02 - edited 01-19-2018 19:03
I dont think you can get new screens fitted. If you think it might be a warantee claim then contact Support (link in my signature) though usually warantees do not cover damage.
Helen | Western Australia
05-06-2018 10:59
05-06-2018 10:59
Same thing happened with mine, the screen cracked during normal wear within the first year of use. (I'm assuming that normal wear includes sporting activities since fitbit advertises use by atheletes)
Fitbit only offered me 25% off a repurchase.
I had ordered my Fitbit HR from Amazon and after talking to Fitbit I contacted Amazon again. The Amazon offered to replace my Fitbit. It should have been Fitbit taking responsibility, not Amazon. Glad I got it fixed but lost a lot of respect for Fitbit as a company and have much lower expectations for Fitbit devices than I had when I originally bought my Alta HR.
05-28-2018 19:58
05-28-2018 19:58
Were you able to get a replacement? We are traveling in a hot/humid climate right now and I've had my Fitbit for about a month. In the heat the screen cracked. Fitbit "customer service" is telling me it's not covered under warranty, but clearly this is an issue/design flaw. As they did with others, they offered me a 25% discount to purchase a new one. WHY on earth would I buy another one when the one I already bought cracked after a month??
05-28-2018 20:07
05-28-2018 20:07
05-29-2018 07:12 - last edited on 06-11-2018 12:36 by FerdinandFitbit
I bought mine through JB hifi so no such luck!
Hi there - I got no where - still have a cracked/scratch screen. Pretty **ahem** service if you ask me! Next time I'll purchase a different brand
Moderator edit: Merged replies
05-29-2018 07:49 - last edited on 06-11-2018 12:37 by FerdinandFitbit
I made sure to buy extended warranty because of friends' and families' stories about defective hardware. I wasn't taking any chances. Fitbit needs to step up it's hardware game!!
Thanks for the information! I'll definitely give that a try.
06-05-2018 11:23 - last edited on 06-11-2018 12:33 by FerdinandFitbit
I just had that issue also. My screen has a crack and I know I didn't hit it. Fit bit only offered me 25% on my next purchase. Unfortunately I purchased it directly from them. I've also lost respect for them. I will never recommend their product to family or friends since this is how they treat customers. I have workmates who from time to time ask me about how I like it. Now my answer will change from being positive. Really sad!
Had my experience with them been better I would have bought a another device but now I have no respect or trust in their products or customer service.
Thanks much. I'll do just that.
06-23-2018 09:18
06-23-2018 09:18
Agree 1000%. I just had the same issue (cracked screen) with a Charge 2. Apparently this is a Quality issue that isn't restricted to the Alta but is across the board. Given that their products are DESIGNED to be tapped on the screen, their failure to provide replacements when fitbits crack under normal use sounds to me a lot like planned obsolescence of their product. Crankly disrespectful and exploitative treatment of their client base. What a letdown!
They offered me 25% as well. Why would I buy another product that is likely to crack?! I'm going with another company.
06-23-2018 19:59
06-23-2018 19:59
Lucky you were offered 25% discount...in Australia, I received NOTHING! Won't buy another one and have warned all my friends to steer clear and go with another brand. When this thing kicks the bucket, I won't be buying another one! What a waste of almost $200
06-30-2018 17:41
06-30-2018 17:41
Same thing just happened to mine. It was in the 90s today in Indianapolis and humid. My screen was fine yesterday but now it's cracked. I was outside in the sun for about 6 hours walking around at my kids lacrosse tournament and now it's broken. Less than 6 months old too.
07-01-2018 11:03
07-01-2018 11:03
I just noticed my 4 month old HR ’s screen is cracked, I have not noticed hitting anything. Seems to be a very sensitive screen. Hope they will soon understand this is an issue they need to adress.
07-03-2018 12:07
07-03-2018 12:07
Appears to be heat related - being out in the sun etc. Known issue for sometime now and not just on Alta HR but also Charge 2 customers are posting about the same problem. Some are getting theirs replaced others just being offered 25% discount on new one.
07-05-2018 14:18
07-05-2018 14:18
Same thing happened yesterday to my daughter's Fitbit Alta screen. In this excessive heat the screen cracked and by today it is spider cracked all throughout the glass. Customer service told her it was the heat and would offer her 25 % off a new Fitbit. Quite a scheme they have going! The Fitbit is less than 6 months old.
They told her to take it back to the store she bought it. They won't return past 30 days.
07-05-2018 14:47
07-05-2018 14:47
07-05-2018 19:54
07-05-2018 19:54
Thank you for your reply. I have told my daughter and she is going to give it a try. Her band is also broken so that may help too.
07-06-2018 20:47
07-06-2018 20:47
Thank you for your response Winnie187. I've just lost all faith in the Fitbit company. It's so sad that they don't care.
07-09-2018 02:12
07-09-2018 02:12
Had the same issue with mine.my fitbit was completely fine and I went for a walk and a crack just appeared across the screen.its clearly a fault with the product as it was sun/heat related.it was only just over 3months old they just offered me 25% off however even with that it's still over £100 and more than I originally paid to begin with.why would I want to buy another faulty product I'm getting a Garmin they don't crack in the sun
07-11-2018 07:12
07-11-2018 07:12
Hi there everyone! Good to see you in the Forums! 🙂
Thanks a lot for taking the time to share your experiences with us! For those who have received a discount, I'm sorry if this is not what you expected 😕
Now, I'd like to know if any of you experienced this while being outdoors and applying sunscreen or bug repellent that was applied on the tracker. I'd like to know if it may have something to do with the Alta HR. If you've been doing this, I'd recommend making sure you remove your tracker when applying these and then put the tracker back on.
Your feedback is very valuable! I appreciate you taking the time to share this with us in advance!
07-11-2018 07:34
07-11-2018 07:34
