04-11-2016 07:31 - last edited on 08-20-2020 18:43 by MatthewFitbit
In my calendar on my iPhone I put my hours that I am in office at work. Its from 10-5, and from 9 am and passed 10 am I kept getting the notifaction on my fitbit alta. Some times it be 10 mins inbetween others it be like every 2 mins. I turned off the calendar notification for now but I was wondering if someone knows the issue?
05-25-2016 16:47
05-25-2016 16:47
Thanks, Erick. That seems to have worked!
05-26-2016 03:53
05-26-2016 03:53
06-07-2016 17:26
06-07-2016 17:26
@SunsetRunner @DCobham Yes! Glad to hear that it worked for you, thank you for the update!
06-11-2016 21:56
06-11-2016 21:56
07-13-2016 13:31
07-13-2016 13:31
My Blaze is constantly reminding me about a Calendar event, even when I hit ignore AND keep swiping to dismiss the event. Even when I am clearly at that event on my GPS on my phone, the Blaze will not stop alerting me. I have the current updates. Can someone please let FitBit know about this and get an update to fix it? Thank you!!
07-13-2016 13:40
07-13-2016 13:40
My Alta was fixed for a little while. Then on Monday I kept getting notifications for an invite event via Outlook. I didn't even have notifications set for that event. I finally had to just delete the event since it was over 3 full days. I guess the fix disappeared on this last update?
07-25-2016 11:10
07-25-2016 11:10
@Kmdcolo @Lynnessa What happens when you restart the Blaze when the notification continues?
@WineScarlet Have you tried restarting the Alta when the notification is going off?
07-25-2016 14:45
07-25-2016 14:45
07-26-2016 08:20
07-26-2016 08:20
Same here, rebooting doesn't fix the problem on my Blaze. Its calendar notifications all day long =/
07-30-2016 10:02
07-30-2016 10:02
08-13-2016 14:11
08-13-2016 14:11
I've got the same problem with my Blaze. The calendar notifications don't stop -- they seem to only "snooze" rather than dismiss and they repeat over and over. I've confirmed that the battery is charged, the software is up-to-date, and I've rebooted. Doesn't help.
10-15-2016 07:55
10-15-2016 07:55
I have this exact same issue with my brand new FitBit Charge 2. I constantly (and seemingly randomly) get notified of my an event (typically my work schedule). It's annoying.
11-04-2016 06:40 - edited 11-04-2016 06:41
I just started getting this notification last night and it continues to go off every 2-5 minutes - very frustrating. The reminder isnt even for something I have on my calendar its for 11:28 pm and traffic? I have tried restarting and checking for updates and nothing ... Any fix on this yet??
11-09-2016 06:17
11-09-2016 06:17
7 months later from the orginal post and this is still happening to my Alta.
Any ideas?
11-10-2016 15:11
11-10-2016 15:11
@Kmdcolo @Lynnessa @Alynk @bowlingotter @jaxadorawho @lilmisslana @samanthamurphy I recommend getting in touch with our Support Team and letting them know that you've tried the restart as a troubleshoot and the result. I am confident that our team will be able to help get you back on track.
11-28-2016 09:06
11-28-2016 09:06
This is happeneing to me as well. The issue went away for a while, but it has now returned after the latest software update. I hope it can be resolved.
12-04-2016 06:06
12-04-2016 06:06
Glad to see you around the Community @pvwon! I'm sorry to hear about this situation.
In this case, if you have already tried the restart suggested in Erick's post above, I'd recommend contacting our Customer Support team, and they will gladly assist you further with this.
Let me know if you need anything else!
Was my answer helpful? Awesome! Let's help our fellow Fitbitters by marking this as a solution, and vote up! 😄
03-20-2017 14:30
03-20-2017 14:30
I am still getting this problem. Not all calendar events do this, but a significant number do. It seems to happen primarily on recurring appointments (which I have a lot of). It will remind me over and over, even if I have dismissed the notification on my phone.
09-27-2017 22:50
09-27-2017 22:50
I only received my FitBit Alta yesterday and new firmware was updated in the process of setting it up. I've been having the same issue with calendar notifications constantly buzzing after the time at which the event has begun.
05-09-2018 07:56
05-09-2018 07:56
Same problem with Versa. The only fix was to disable notifications for outlook. One more swell feature I paid for but can't use because it is just freaking annoying and sucks the battery. You guys gonna fix this for the versa?
