03-09-2017
15:04
18:17
03-09-2017
15:04
18:17
My fitbit alta doesn't work unless it is plugged in. I think there may be an issue with the battery, is it possible to replace the battery?
03-09-2017 15:06
03-09-2017 15:06
Welcome to the forums!
It is not possible to change the battery
Please clean the contacts
http://help.fitbit.com/articles/en_US/Help_article/My-tracker-s-battery-isn-t-charging/?q=not+chargi...
Then Do a Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
If it doesn't help Contact Support
http://help.fitbit.com/?cu=1
Please join us in the get moving forum! Lots of great people here!
Wendy | CA | Moto G6 Android
03-10-2017 06:51
03-10-2017 06:51
It's great to see new faces around @Meeka333!
It's a shame to hear that you're experiencing this inconvenience. Great troubleshooting tips provided by @WendyB, I just would like to add the charging best practices and I've also attached the video of how to charge the Alta just to double check that you're doing properly.
Let me know how it goes!
03-10-2017 07:11
03-10-2017 07:11
Thank you. I called support and they confirmed my device was detective and they're sending me a replacement.
Best Answer03-10-2017 09:29
03-10-2017 09:29
Hi there @Meeka333!
You're more than welcome! It's great to hear that you're getting a replacement, don't forget to do the setup process once you get it.
Have you checked our Discussions board? There you can share your story, find some fitness tips, recipes and more! Give it a look!
Hope to see you posting more often!
10-09-2018 11:29
10-09-2018 11:29
Did you find a way to fix/replace the battery? I called support and I am just out of warranty and I have to buy a new one (which I cannot afford).
10-09-2018 11:43
10-09-2018 11:43
Best Answer05-28-2019 11:18
05-28-2019 11:18
why would fitbit build a product that runs on batteries but the battery cannot be changed?? doesnt make any sense to me.
08-19-2019 15:27
08-19-2019 15:27
I have the same problem and question
08-19-2019 15:31
08-19-2019 15:31
how much is it?
Best Answer08-28-2019 16:51
08-28-2019 16:51
Hi @Skylar07
You can't swap out the battery in the Alta, just like you can't swap them out in some smartphones. Was that your question? Can't give you a price, since it's nothing that can be done.
Best Answer09-13-2019 11:14
09-13-2019 11:14
Can't change a smartphone battery? Who are you, Apple? Anything with a battery can be changed. To change the Alta battery you have to heat the screen up like an Iphone screen to melt the glue, but move the heat quickly so you don't damage the screen.
Then lift off the screen, unscrew the board inside, and replace the battery. whole thing takes about 15 minutes if you go real slow. If you go fast, you can do it in 5.
Yootoobe has videos on it.
Best Answer09-13-2019 14:20
09-13-2019 14:20
Hi @FitTHISbitSon not everyone feels secure enough in doing this alone. Some people don't have the skills to do it and/or the necessary tools. Anyone is free to search online for solutions, but as for Fitbit, they don't suggest doing it.
Best Answer09-13-2019 14:29
09-13-2019 14:29
The question wasn't "Can anyone without any tools change a fitbit battery" though, now was it?
11-17-2019 09:36
11-17-2019 09:36
upvote x 10
Best Answer12-31-2019 11:29
12-31-2019 11:29
Of course Fitbit doesn't recommend doing it! They want you to throw yours away and buy a new one. 😞
01-05-2020 16:27
01-05-2020 16:27
I doubt it is the battery, and there is no need to heat it up, the face is held in with a silicone seal and 4 clips. Since mine is not working I felt okay with simply prying off the face with a box cutter (it is simple, but I could see it easy to mess up, so I am not suggesting anyone else do it...).
I get 4.2 volts off the battery, it went down the 3.9 after a few days, but I don't think this is a battery issue, as I can keep mine on if I actively tap on the screen after unplugging it. I have done so for 5 minutes and it stays on, but once I stop, it shuts off (and still has 4.2v where the battery connects to the board).
I am building a machine to tap it and see how long it will stay on, 5 minutes was all I had in me, that was tough.
Best Answer04-05-2020 12:19
04-05-2020 12:19
My Alta dies within minutes of charging.
04-26-2020 22:29
04-26-2020 22:29
I don’t want to change the battery but why does it work while on the charger and unplugged it is dead says fully charged and stuff I waited hours for chat supprt on Fitbit queue 80+ and it didn’t even work I was disconnected and disappointed
i Ann sure it’s a hardware issue and even as it’s new I guess nothing I can do ?
04-26-2020 22:37
04-26-2020 22:37
Hi @Somerton09 the Alta was retired and isn't being sold new by Fitbit. It was replaced by the Inspire series. You might want to try restarting it a few times, but sometimes the batteries do die. Support here, as with many other companies, are super busy and it takes time to get through. I've spent a lot of time lately with Walmart on the phone and have waited as long as two hours, sad to say. Where did you get your Alta?
