03-14-2016 13:19 - edited 08-20-2020 18:43
One of the trickiest parts of getting started with a brand-new wristband tracker is simply learning how to get it clasped properly. The following post can help you with that!
How do I clasp my Alta wristband more easily?
We're confident that you'll be able to get your alta clasped with just a little practice. Don't be discouraged if it's difficult at first - it definitely gets easier over time!
How do I change my Alta wristband?
Fitbit Alta's wristband is detachable from the top and bottom of the tracker, so that you can replace it with accessory bands of different color or material. For help with detaching your Alta's wristband, check the steps in this help article, or watch the video below.
03-16-2016 11:46
03-16-2016 11:46
03-16-2016 11:59
03-16-2016 11:59
At first they are hard to put on. But it does get eaiser with use.
Wendy | CA | Moto G6 Android
03-16-2016 13:02
03-16-2016 13:02
03-16-2016 13:03
03-16-2016 13:03
@Vitti @sandy_su Please check my post above for some tips that might help. If you use both hands to repeatedly clasp and unclasp the device without wearing it, that should help break it in so that it's easier when you put it on with one hand. It definitely gets easier over time!
03-16-2016 13:55
03-16-2016 13:55
I don't like to sleep with it but I re-clasp it when I go to bed and leave it on the nightstand, and that seems to be stretching it a bit. It's getting better.
03-16-2016 15:31
03-16-2016 15:31
03-16-2016 16:47
03-16-2016 16:47
So far I haven't even been able to clasp it when it's off my wrist much less on. Pretty disappointed right now.
03-16-2016 16:49
03-16-2016 16:49
@speedlady I promise that it gets easier over time. If you aren't able to get it clasped using both hands, you might try soaking the band in warm water to loosen it up, or ask someone to assist you. Once you're able to clasp and unclasp it a few times, it should be much easier.
03-17-2016 07:32
03-17-2016 07:32
03-17-2016 09:30
03-17-2016 09:30
I could't get my clasp to work at all. I finally put a drop of olive oil on the band and not it works fine. Too bad they didn't make it easier.
03-17-2016 21:28 - edited 03-17-2016 21:57
I haven't been able to connect the little posts through the wristband either, even off my wrist! I hope there are some better wristband options out there, or my brand new Alta might need to be returned, and my trusty Zip to the rescue!
03-17-2016 21:53
03-17-2016 21:53
03-18-2016 06:44
03-18-2016 06:44
03-18-2016 09:12
03-18-2016 09:12
I had difficulty with the clasp on my Alta until I slid something under it and then pressed down. It seems to need a firm surface under the band, at least until the holes become a little more flexible. I have very small wrists also. I love the color of the band (purple!).
@moocow wrote:Is anyone else having trouble getting the little spikes through the holes in the band to close it? it just pops open constantly - will probably lose it the first time out!
03-18-2016 09:27
03-18-2016 09:27
Yes!!!! Thanks for the tip! The olive oil did the trick, first try!
03-18-2016 10:23
03-18-2016 10:23
I had no issues with getting the Alta on at all. I put the Alta screen side down on a soft surface. I think put my wrist in and push the upper clasp in only to start. I squeeze it with my thumb and pointer finger. Then I snap the bottom one in place once the top one is secure. I tried a couple times putting both in at once and that was not working.
03-18-2016 13:46
03-18-2016 13:46
don't take this the wrong way..The first time i tried to line up the prongs it was "difficult". Not as difficult as hanggliding or running a marathon...just line up the holes and push,,and when it doesn't go in..realign the pins..
Opening the package with the Alta was much harder than pushing in the pins!...line up the pins with the ALTA
off your wrist and push them thru a few times..within a few days it will be automatic
03-19-2016 07:47
03-19-2016 07:47
03-19-2016 08:38
03-19-2016 08:38
I used a drop of olive oil on mine and it works like a charm. I was going to send mine back. Love it.
03-19-2016 08:39
03-19-2016 08:39
Yes! My husband has to put it on me too. I've been trying and trying to get it on myself and just can't.
