03-14-2016 13:19 - edited 08-20-2020 18:43
One of the trickiest parts of getting started with a brand-new wristband tracker is simply learning how to get it clasped properly. The following post can help you with that!
How do I clasp my Alta wristband more easily?
We're confident that you'll be able to get your alta clasped with just a little practice. Don't be discouraged if it's difficult at first - it definitely gets easier over time!
How do I change my Alta wristband?
Fitbit Alta's wristband is detachable from the top and bottom of the tracker, so that you can replace it with accessory bands of different color or material. For help with detaching your Alta's wristband, check the steps in this help article, or watch the video below.
03-21-2016 06:32
03-21-2016 06:32
03-21-2016 07:28
03-21-2016 07:28
03-21-2016 08:22
03-21-2016 08:22
Send it back?
I'd rather the band with the holes be a bit tight,,rather than than sloppy loose and the thing fall off. I was
inconvenienced for about 3 minutes trying to get it on. Now the band trained me on where the prongs
should meet the same holes every time, its like putting the right shoe on the right foot,,
As for buttons,,,,they would be itsy bitsy and we'd have a 3 month discussion about the size. placement,
functionality or lack of operation.
I love mine, it's become a part of me..
03-21-2016 15:35
03-21-2016 15:35
03-21-2016 15:44
03-21-2016 15:44
03-22-2016 10:14
03-22-2016 10:14
I feel your pain. Kinda a toss up of not taking a shower, or removing the Alta. It's frustrating!
03-27-2016 21:17
03-27-2016 21:17
I purchased my Alta with the Black Bsnd and also the optional pink leather band . It's a good think I did because there's no way that I could even get the blackband fasten it's like hard plastic the stainless steel clasp absolutely will not pop through the holes . When I switched to bands and put the altar on my pink leather band I had absolutely no problem fastening it ! good thing I planned on using the pink leather 99.9% of the time . However when I work out I wanted to use the black plastic band because I didn't want my pink leather to wear and be subject to sweat , water etc. i'm very disappointed I paid so much money for a product that I can't even use !
03-28-2016 06:36
03-28-2016 06:36
03-28-2016 09:42
03-28-2016 09:42
03-28-2016 11:20
03-28-2016 11:20
@Ineedsun@xelaito@zoie47@CDP2538 I recommend doing as @MatthewFitbit's lead-in post suggests of"clasping and unclasping your wristband at least a dozen times using both hands, without wearing it." I think that should help loosen up the holes enough to make it easier.
@Zannie@mugs1937@BJCushing@betsyg@farmwife24@Carolyn44@SunsetRunner@2016gymgirl Another suggestion that you could follow is to add a drop of olive oil like @Gmadiane@speedlady mentioned doing above.
@Vitti@Diamondgirlde It should loosen up after several days of wearing it and clasping it into the same holes everyday.
@Vitti Be careful that the awl doesn't tear the holes, which could make it too loose.
@janet34sail That's why I slide my index finger underneath the wristband and push on the clasp from the outside with my thumb. That usually gets it in for me with not much force.
@dmama1314 Glad that it was an easy process for you!
@CVG1 Yes, after a few days of wearing it and taking it off and putting it on, it will loosen up the holes to make it much easier to clasp. I also use the suggestion of putting my index finger in the back and then pushing the clasp through with my thumb, as shown here.
@Zannie We currently do not have a date to share as to the release of the Alta stainless steel band, but you can sign up to be notified with updates here.
@SunsetRunner It depends on what wrist you are wearing the Alta. In the image here, the user is wearing the Alta on the left wrist.
@BianchiDoodle Yay! Happy to hear that the suggestions in the lead-in post helped you out.
03-28-2016 12:36
03-28-2016 12:36
I just got mine today and I've been fighting for the last hour to get it on. I finally did but now I'm afraid it's not going to stay on. i was switching from a Charge HR because of the size but I might just return this and go back to the Charge. Didn't they do any consumer testing? Obviously there are a lot of people with this issue.
03-28-2016 13:01
03-28-2016 13:01
@GracieA Sorry to hear of the trouble you've had with clasping your new Alta. As @MatthewFitbit pointed out in the lead-in post of this thread, it will get easier over time. I also suggest checking out this post in which @MatthewFitbit talks about the improvements we've made to the Alta clasp.
03-28-2016 14:39
03-28-2016 14:39
It does get easier. Mine was a bear for the first half-dozen times, but no problem now. It seems really secure....as long as you make sure the clasps "pop" or "snap" in. I think the band is softer than the Charge band is. I'm loving it, once I had a handle on snapping it securely.
03-28-2016 17:19
03-28-2016 17:19
@SometimesLucy You're right! I can totally hear mine "snap" in to the holes. That tells me that it is secured on. The wristband is extremely confortable on my wrist and I sometimes don't even notice that I am wearing it. Thanks for the feedback, glad to hear you're enjoing it!
03-29-2016 09:27
03-29-2016 09:27
Can it be worn more loosely? In that I mean have the clasp connection be farther back so you can slide the Alta on and off like a bangle bracelet? Will it still register correctly?
That way there is no clasping/unclasping to shower or other times.
03-29-2016 11:42
03-29-2016 11:42
I wear mine a little loose sometimes, and it doesn't seem to cause a problem....
03-29-2016 12:32
03-29-2016 12:32
@Jbjb93@SometimesLucy I recommend wearing the Alta tight enought o not move around on your wrist but loose enough to comfortably fit a finger in between the tracker and your wrist. You can find more about our recommend wearing tips for Alta here and here.
03-29-2016 12:46
03-29-2016 12:46
03-29-2016 15:29
03-29-2016 15:29
03-29-2016 16:40
03-29-2016 16:40
I have RA and I'm not able to put my Alta on by myself, I'm so disappointed!!
