10-13-2017 15:31 - last edited on 08-20-2020 18:17 by MatthewFitbit
Wont sync, won't work unless on charger, then intermittently! This is getting to be long term. Done 2 upgrades, deleted app and reinstalled x2. Phone turned off on many occasions. Shows fully charged on FB yet battery level on app states medium. Left for over a week so battery would go flat and fully recharge, still showing battery as medium.
Is it possible that my fitbit has dementia?
06-29-2018 14:18
06-29-2018 14:18
Welcome to the Forums @KateAldara, and @mollyfitz! I appreciate that you have shared your experience with your Alta and for the troubleshooting you have performed before posting here.
@KateAldara I've created a Support case for you. Please, keep an eye at the email you used to register with the Community forums. Keep me posted if you have any other question.
@mollyfitz To further assist you can you please confirm that you have tried the suggestions on my previous post.
I look forward for your reply! 🙂
07-11-2018 18:14
07-11-2018 18:14
I have been having the same issue, if I plug it in to the charger I can occasionally see the clock but usually just the battery icon. I did a full restart of the Fitbit, disconnected from the app, deleted the app and reinstalled/setup and I got a minute of being able to click through the screens as usual but then following that I was back to only seeing the battery icon showing full charge when on the charger. There’s no response to tapping, flicking, nothing like that. Thank you for any assistance you can provide!
07-12-2018 09:17
07-12-2018 09:17
I have been having the same issue, my fitbit alta won't hold charge unless if I plug it in to the charger I can occasionally see the clock but usually just the battery icon. I did a full restart of the Fitbit. Goes dead again. There’s no response to tapping, flicking, nothing like that. Have to plug in to the charger and it shows it has half of battery still but why it doesn't work? I notice many have the same issue. I have my Alta since Dec 2016. Thank you for any assistance you can provide!
07-21-2018 00:24
07-21-2018 00:24
@LucyAP hi, I have tried all the suggestions but still it does not work.
07-21-2018 00:26
07-21-2018 00:26
@LucyAP I have tried all the suggestion but it still does not work
04-04-2019 06:15
04-04-2019 06:15
Lucy - Is that case a couple of years old? If so that is the last Alta that stopped working and I had to buy a new one. Should I create another case?
04-08-2019 22:02
04-08-2019 22:02
Hi! I recently got a Fitbit Alta and it charges and works fine whenever I'm connected to the charger but as soon as I take it out of the charger, it becomes unresponsive. Solutions?
05-14-2019 11:42
05-14-2019 11:42
I am having the same problem with my Alta.
06-06-2020 19:05
06-06-2020 19:05
Hi there! I know this forum is about 3 years old, but I'm having the same problems as the original user. I've also cleaned the device, and my problem is still the same. Due to COVID, FitBit's Live Chat is currently down, and I'm not sure where else to go for help.
06-06-2020 19:20
06-06-2020 19:20
06-06-2020 19:28
06-06-2020 19:28
07-07-2020 16:59
07-07-2020 16:59
Same issues!
