04-15-2017 12:12 - last edited on 08-20-2020 18:17 by MatthewFitbit
I'm away from home and I forgot my charger at home. It died this morning and I won't be home for another 2 days. I'm missing out on loads of steps because it's dead so is there any possible way I can get a bit of charge in it without a charger ???
04-15-2017 14:22
04-15-2017 14:22
Welcome to the forums!
I dont know where you are but if there is a Best Buy you can go they and they will let you use a charger.
This is the best charging practices
Also, other tips to best charge Fitbit trackers are:
- Use only genuine Fitbit charging cables.
- Use only UL-certified wall chargers.
- Avoid USB battery packs.
- Charge at room temperature.
Look around the forums and join in on some of the discussions! Lot's going on!
Hope to see you around!
Wendy | CA | Moto G6 Android
07-21-2018 14:57
07-21-2018 14:57
Hello,
You seem like you are in trouble. You can buy a charger in a local electronic store,Best Buy, or any other electronic store
Best of luck! Ninja
02-17-2020 18:18
02-17-2020 18:18
I have a fit bit blaze and I don’t have a charger to it and I’m trying to figure out how to charge it without the charger so if u know how to without all those cord and wires stuff plz reply to me on how to do it
