07-14-2016 06:59 - last edited on 08-20-2020 18:17 by MatthewFitbit
07-15-2016 06:59
07-15-2016 06:59
Welcome to the Community @robynleighton! I hope you're doing great!
Let me help you out, What happened to your tracker? what type of issue are you experiencing? in order to restart it double check you're following these steps:
1. Plug your charging cable into a USB port on your computer or any USB power adapter.
2. Insert the other end of the cable into the port on the back of your Fitbit Alta. Your Alta will begin charging.
3. Press the button on your charging cable three times within eight seconds, briefly pausing between presses. The button is on the end of the charging cable that is plugged into your computer.
4. Eight seconds after the first button press, you'll see the Fitbit logo on the screen. This means Alta is restarting.
5. After you see the logo you can unplug your tracker from the charging cable.
Catch you later!
03-13-2017 08:09
03-13-2017 08:09
Was this ever resolved? My Alta did not reset overnight. I've followed these steps multiple times this morning and it will not reset my steps back to zero.
03-16-2017 19:36
03-16-2017 19:36
Mine won't reset either. Did you figure out how to do it! Please let me know!
04-02-2017 22:06
04-02-2017 22:06
My IOS App is continually "looking" for my Alta. I tried the restart instructions that you just restated about ten times to no effect. Are there no other fixes? Did the original poster ever get hers working?
04-03-2017 19:14
04-03-2017 19:14
I have tried reseting my tracker,just like it says and it will not reset,is there anything else I can try?
05-31-2017 10:20 - edited 05-31-2017 10:22
My Alta doesn't restart either. Tried the steps multiple times, varying the length of time I wait between pressing the button. The battery flashes each time, so I know it's registering my button pushes, but I never get the Fitbit logo.
My original issue is that it won't sync yesterday or the day before. Usually I sync every day, but this time I waited a couple of days. It continues to look like it's syncing but never ever completes. I've followed all of the other steps to fix syncing, to no avail.
The only other thing I can think to try is to let it run completely out of batteries before plugging it in again. Assuming that would do the same thing as a restart. I'll let y'all know if that works.
06-04-2017 10:32
06-04-2017 10:32
I don't think letting it run out of batteries did anything because it never completely ran out -- always at least had the ability to show me that I was out of batteries, and then I realized that if I let it go out completely, it might lose what it had in memory.
So I tried the reset and got it to work. The trick is to do the reset not within the 8 seconds that the instructions say, but within about 2 seconds. Once I did it as fast as I could, I finally got the logo. Fitbit is now syncing. Yay!
07-14-2017 06:38
07-14-2017 06:38
I have been trying for days to reset according to directions and suggestions and its just not happening. Occasionally it appears the reset worked, but then nothing. The tracker is fully charged.
08-01-2017 07:50
08-01-2017 07:50
I have the exact same trouble! My fitbit started having trouble syncing a few months ago. Tech support was able to help me get synced again by turning off phone Bluetooth, rebooting phone, resetting Alta, then turning on Bluetooth. It used to be that the app would show todays steps, but the days before was gone. I've always had trouble resetting my Alta so varying the length of time between button pushes sometimes works, sometimes doesn't. Since the length of time between button pushes is never the same, I cant find the pattern. Today it just wont reset at all and I've tried as many variations of button pushes as I can think of. UGGGGG
09-03-2017 20:30 - edited 09-03-2017 20:30
Mine wouldn't restart lately either. I cleaned the contacts on my Fitbit where the charger connects to my Fitbit, and tried again. First try and the logo appeared.
09-04-2017 14:29
09-04-2017 14:29
I was having the exact same problem. I synch my Alta to my Android phone. I restarted my phone, turned the bluetooth back on and then it synched successfully.
11-04-2017 09:16
11-04-2017 09:16
I noticed it wasn’t syncing this morning, so I tried to reset and nothing happened. I plugged into my computer; still nothing. But when I sa your tip, I cleaned the back of my Alta, and presto! First try, it reset!
Thank you!
12-10-2017 16:54
12-10-2017 16:54
Thank you JoyShafer! Using the quick method you suggested I finally got my Fitbit to reset! 😆
12-11-2017 03:29
12-11-2017 03:29
I am having the same problem. There is no buttone to press on my cable. My Altra was a gift last Christmas.
Sheila
12-20-2017 09:33
12-20-2017 09:33
I was having the same issues with no syncing and not being able to get my Alta HR to restart. I tried this, pushing the button three times very quickly within about two seconds, and it restarted! It still won't sync, though. I unpaired the Alta from my Bluetooth, and now it won't re-pair.
12-31-2017 11:30
12-31-2017 11:30
This answer is all over the forums, and it still does not work. Pressing three times in eight seconds, over and over again repeatedly does not work. It just doesn't. Give a better answer, or give me my money back.
12-31-2017 12:07
12-31-2017 12:07
01-09-2018 00:13
01-09-2018 00:13
fitbit screen is working when plugged in to the charger but wont reset and when take off charger screen doesnt show
01-11-2018 11:16
01-11-2018 11:16
I have tried several times to reset my Fitbit Alta. It’s 1 year old. What should I do. I have to charge it every other day. It will not reset. I have cleaned the contacts.
