03-15-2016 19:44 - last edited on 08-20-2020 18:43 by MatthewFitbit
06-15-2017 22:36
06-15-2017 22:36
Is there any way that the charter could be harmed? I have tried different USB ports and tired restarting my Alta but it still doesn't buzz or charge. 😞
06-23-2017 18:41
06-23-2017 18:41
Thanks for your help...did what you suggested and my Alta is now charging!
06-23-2017 18:49
06-23-2017 18:49
06-23-2017 23:44
06-23-2017 23:44
Who did you reply to????
06-24-2017 19:14
06-24-2017 19:14
06-27-2017 21:38
06-27-2017 21:38
I just received my fitbit alta from amazon. I did everything it said in the setup. Plugged it in and I got nothing. I have left it for about 3 hours now and nothing. I have also tried the reset multiple times. Very Frustrated!
07-06-2017 07:45
07-06-2017 07:45
I have tried the reset several times and nothing. Still the wrong date wrong time and wrong steps. What's next?
07-06-2017 11:49
07-06-2017 11:49
07-07-2017 03:39
07-07-2017 03:39
Bought a Fitbit Alta for my girl friend in January. For over a month now it will not start, it wont hold a charge and it wont track. "This Dog wont Hunt"
Tried resetting it many many times.
07-14-2017 18:06
07-14-2017 18:06
It didn't work. What else can I try?
07-21-2017 04:11
07-21-2017 04:11
I have the same issue, a ! mark display after overnight charge in port of computor. I have pressed the button 3 times as directed no difference, still no charge showing, if I didn't leave enough seconds between presses - have I turned the alto off now? how often can I try the 3 presses?
07-21-2017 16:53
07-21-2017 16:53
My fitbit Alta quit tracking on app. I uninstalled and reinstalled. then signed back in. No luck. I would follow your instructions but my fitbit does not have any buttons to press.Thank-you so much
07-22-2017 18:25
07-22-2017 18:25
07-23-2017 13:09
07-23-2017 13:09
07-27-2017 19:36
07-27-2017 19:36
I can not get my Fitbit Alta to reset at all. I have followed your steps above but it won't reset my Alta is displaying an incorrect time. Help!
08-01-2017 19:22
08-01-2017 19:22
Where is the button on my charging cord, I don't see one?
08-02-2017 14:16
08-02-2017 14:16
08-15-2017 07:44
08-15-2017 07:44
I facing same problem with my surge as I unplugg it completely goes off
08-16-2017 01:04
08-16-2017 01:04
08-25-2017 13:45
08-25-2017 13:45
Where is this "button on your charging cable" ????
