I've recently started to use the Fitbit app on Pixel Watch to track my runs, and noticed a bug with auto-pause. With auto-pause enabled, the run will track on the watch, pause and resume, and appear to continue to track, but at some point it loses the ability to continue to save data. It appears that location data continues to be saved but the distance elapsed somehow resets to 0. This causes the loss of run distance information after the reset and no statistical analysis is possible in Strava.
The following is a screenshot of the TCX file. This is almost certainly an auto-pause problem because the time increment jumps by 5 seconds (from 19:56:47 to 19:56:52) while the GPS coordinates is unchanged (I recall I briefly stopped to tie my shoelaces). When this is propagated to Strava, the run shows its full route, but distance fails to increment after 8.1 km.
However, the watch and the Fitbit app recorded the total distance and heart rate correctly, with exception to the map:
What makes this problem insidious is that there is no indication from watch/app side (during the exercise) that a problem has occurred. I had no idea these issues happened until reviewing the exercises days later when I found out my planned and actual distances didn't match. Needless to say, this makes the device unusable for serious training unless I resort to manually pausing and unpausing.
I've had a similar with cardio-centric workouts on my Pixel watch 2 ever since the most recent pixel watch firmware update.
Whenever I am on the treadmill or an elliptical it will constantly auto-pause and then immediately resumes and often when I finish training the final results won't nearly line up with what I was doing. This is happening in spite of me having automatic workout tracking off and regardless of is the sweat lock is turned on. I've rebooted my watch a couple times now, doubled checked my settings to make sure I wasn't going crazy, and thoroughly cleaned my watch to make sure there wasn't any crud in there hitting a button or something. It also does not seem to make a difference if I wear my watch tightly or loosely. I mention that it's only cardio-centric workouts because when I have it tracking my weight lifting this does not happen.
This only started happening after that firmware update and I've always taken good care of my pixel watch.
Best AnswerHello @benasaur , @ItsMelvin
Thank you for the information on this issue.
Please submit this issue using the Feedback option in the Fitbit app:
Although it's likely that you won't receive a response, we've gotten confirmation that the team reviews every submitted feedback report and uses the information for issue investigation.
