The Fitbit app seems to be causing issues with my LG V20. It drained the battery to half in about 3 hours and seems to be causing my phone to lag and hang. Is this a widespread issue? Is there a fix to this? I've looked through the forum and have turned off the "all day sync" function and kept "always connected" on. Seems like the app itself should be reprogrammed to run better in order to have all the functions active without causing problems like this.
Thanks.
@MursePaolo, have you looked a the phones Battery Usage chart to see what the battery high usage apps are? Also, did you shut down the phone and restart it after you installed the Fitbit app?
