I have had two updates on my Sense 2, so far when I unpair and pair my Sense 2 to the app. Still have not got the battery percentage showing on the main screen on the Fitbit app. Still shows Oct. 2023 update on the app install in Google play store. Doesn't show update on install in the play store.
I have only a small picture of a battery on the sync tab with no percentage amount showing.
Best Answer@sparkles4 I moved your post to the Android app forum, a better fit for your question. Please check back on this forum for information on the Android app.
Laurie | Maryland
Best AnswerHello @sparkles4
The % battery is supposed to be in the latest app update, version 4.04. The app updates tend to rollout gradually.
Like you, I'm still waiting for the 4.04 app update and am checking the Play Store daily. Hopefully, we'll see it soon.
