01-06-2017 07:27
01-06-2017 07:27
I'm having issues with my Blaze staying connect to the bluetooth on my S7 Edge. I begun having issues when I set up the Blaze Classic bluetooth connection while I had the other bluetooth connection through the app. I'm not sure if it is a Blaze issue or a S7 Edge issue. Just wondering if anyone else is having this issue.
Best Answer01-06-2017 19:36
01-06-2017 19:36
@trm0314, turn off or disable WiFi on the Samsung phone and then try syncing the tracker to see if it stays connected. Many Samsung phones have hardware conflicts between the Bluetooth and WiFi, so this may be an issue if you are using WiFi.
