08-13-2017 14:22
08-13-2017 14:22
My blaze will not remain paired with my phone. It's been this way since the last update. I will get them to pair and the manually update. Then it will turn off. How do I fix this?
Best Answer08-14-2017 06:54
08-14-2017 06:54
Hello there @Shuppenshade, welcome to the Fitbit Community! Certainly this is not a normal behavior and I'm wondering what update you are referring? Is it an update with your Fitbit app or the OS of your phone?
I would recommend to do the following:
- Restart the app and clear the cache using the following steps on this post.
- If this is not working try to sync your tracker and proceed to uninstall the app, restart your phone and reinstall it again.
Hope this get you back on track. See you around!
