03-20-2020 11:26
03-20-2020 11:26
Hi,
I noticed that my Charge 3 was 5 minutes slow. When I checked my fit bit phone app there was no synch update since some time in January. I tried synching but it failed. I checked the bluetooth connection but it wasn't there. I tried to reconnect my fitbit but it didn't reconnect. I looked up the Fitbit suggestions for bluetooth connection troubleshooting and I've done every single suggestion.
I've now disconnected every bluetooth thing from my phone and my Charge 3 still won't connect. The phone says it sees the Charge 3 and the Charge 3 supplies a 4 digit connecting code which I input to the fitbit app on my phone, then the phone says it's connecting and it keeps trying. A message appears saying it's taking longer than expected but "we're on it!" Except it keeps failing. I've tried at least a dozen times, no exaggeration. And yes, both phone and fitbit are connected to their chargers when I undertake every frustrating attempt. None of your advice works. Please advise.
Thanks
Helen
Best Answer03-20-2020 12:12
03-20-2020 12:12
I've also been experiencing syncing issues. It started with my Alta HR that I troubleshooted with a Fitbit support person. They suggested a new Fitbit. I bought a Charge 3. It synced on Day 1 and at some point, unpaired itself with my phone and now won't pair or sync. Not with my phone or my computer. I've done all the things (uninstalled and reinstalled, restarted my phone, disconnected all paired devices, searched forums, checked settings on my Charge and my phone and my laptop, etc.) I'm guessing if others are having the same issue, it's a Fitbit issue? What's Fitbit doing to correct this problem? I'm more than a little mad that I bought a new device on Supports suggestion and it turns out it wasn't my device at all.
Best Answer03-20-2020 12:19
03-20-2020 12:19
Best Answer03-20-2020 20:27
03-20-2020 20:27
I am having the same problem. Carge 3 keeps losing time and I have done everything, but for naught. Fitbit did and update March 17 and my problems began around that time.
Best Answer03-20-2020 20:59
03-20-2020 20:59
Hopefully they can help us.
Regards
Helen
Best Answer03-22-2020 17:07
03-22-2020 17:07
Best Answer11-29-2020 17:07
11-29-2020 17:07
Um, it is now November. Has anyone come across a fix yet?
Best Answer12-01-2020 00:00
12-01-2020 00:00
Anyone been able to sync the Fitbit Charge 3 consistently? Any other device seems to pair in seconds. On the Fitbit I have to try a few times. The Bluetooth connectivity also keeps dropping.
Best Answer12-01-2020 11:33
12-01-2020 11:33
There was a time that I could connect and sync my Charge 3 to my Samsung galaxy S10+ and my laptop running Windows 10 Pro via Bluetooth. Now I can't sync to either one. In my phone it will recognize the Charge 3 but it won't sync. In the laptop it used to show up in the printers and devices folder as Charge 3 via Bluetooth. What ever recent update to the firmware probably corrupted the stack. There should be a patch for release by now.
