09-03-2024 17:15
09-03-2024 17:15
This weekend My Fitbit app dashboard started showing different numbers for calories burned and calories out in the food log.
Additionally in the food log, it is also showing calories out for the next three days.
I have uninstalled and reinstalled the app (device is Android 14), tried the app on another device and factory reset my Sense and still have the issue.
I appreciate any additional recommendations to fix the issue
Thanks
09-04-2024 12:21
09-04-2024 12:21
Mine was doing the same thing. After I uninstalled and reloaded the app on my phone the dashboard no longer shows any calories out!!! My Sense still shows them but the app doesn't. I'm really fed up with Google and the way they have dumbed down and screwed up Fitbit!!!
09-04-2024 14:03
09-04-2024 14:03
Now for no known reason, my dashboard magically started working properly again. Go figure.
09-05-2024 20:28 - edited 09-06-2024 18:56
Mine worked right for one day and then back to the same issue. Really wish they would get this fixed use it to help with my weight lost
09-06-2024 09:25
09-06-2024 09:25
Mine is still showing inaccurate calories burned in the food tracking and calories burned for the next three days. Hoping they fix this soon
09-06-2024 20:27
09-06-2024 20:27
My guess is there's something glitchy going on about how it estimates whether you're on track to be within your budget. The under/ over/ in the zone has always varied between the dashboard and the food details and took some getting used to.
This calories out mismatch is a problem though. It was one thing to think "maybe I'll have some calories left in my budget IF I continue being somewhat active today." But making me think I've actually burned calories that I haven't is counter productive.
Upvote and get this on Google's radar. There have been a few times recently where it seemed functionally had been lost when in fact it was there but I just couldn't find it with all the changes.
09-09-2024 08:48
09-09-2024 08:48
I'm having the issue minus the 3 days ahead food log. My calories out are nearly double the calories burned (showing accurately in the calories burned section, so no issue with syncing). I have un-installed the app, restarted my phone, restarted my Inspire 3, cleared cache, cleared data, etc. and nothing works! It'll show correct for just a moment before it connects to the device again, then bam, back to double calories out 🤦🏼:female_sign:
09-09-2024 10:55
09-09-2024 10:55
09-11-2024 14:38
09-11-2024 14:38
Mine too and it started doing this all of a sudden
09-11-2024 15:47
09-11-2024 15:47
Update contacted support and got the were working on it. Hope it is fixed soon
09-11-2024 19:53
09-11-2024 19:53
Thank you for the information. I have been having the same issue with no luck fixing it on my own and no luck getting ahold of customer support. Hope they can fix this soon.
