Changing body fat percentage
ANSWERED
After weighing myself this morning I used calipers to check my body fat percentage, as I do every few weeks. I measured a drop of 1%, which I tried to record in the app but for some reason it won't save. I changed the number in the relevant field, but after saving the entry it reverted back to what it was before.
I have tried editing the entry and also deleting, then re-entering it. Neither approach has worked.
It's a fairly minor thing but I feel my health metrics will be inaccurate unless I can change it. It's there some way of fixing it?
1 BEST ANSWER
Accepted Solutions
Hi!
I'm a bit confused when you say you have tried to reenter and delete, I made you a Video, and hope it helps.
Edit Fat%
Fitbit user since September 2019
Sense2 Sense, Charge3, Android, Windows
2 REPLIES 2
Hi!
Edit Fat%
@LokeAa thank you, this worked. I was trying to do it on the same screen where you log your current weight, but it would always change back. This time it has changed.
