I have just received my first Fibit device - Charge 2, but unfortunately, the Charge 2 has not been able to pair with my Nexus 6P. And I have also tried my wife's IPhone 6S with no luck. Any thoughts or help will be much appreciated.
Hey, @EvanHsiao! It is nice to see you. I recommend you to restart your Charge 2, then log out from the App, log back in and try to sync. If this doesn't work you can try to set it up using a computer and then you will be able to sync normally. To restart your Charge 2:
Give a try and let me know! ![]()
Hey, @EvanHsiao! Thanks for the updates. In this case I suggest you to contact our Customer Support team since they have some tools to check your tracker's behavior.
Let me know what they say! ![]()
