01-27-2017
11:51
05:27
LanuzaFitbit
01-27-2017
11:51
05:27
LanuzaFitbit
I have a Samsung S7 edge and my phone and text messages are not allerting my Fitbit. The notifications is switched on, I have synced,I have turned Bluetooth on and off, I have re paired the devices and still nothing. It used to work and then just suddenly stopped. I have tried all the Fitbit help and troubleshooting. Can anyone help? Many thanks.
04-13-2017 07:20
04-13-2017 07:20
It didn't work for me, mine has never worked. I have Nexus 5X, it is on the list of compatible phones. How do I re-pair?
04-13-2017 14:16
04-13-2017 14:16
A very warm welcome to the Community @Nannabug!
Since the steps mentioned didn't resolve the situation, let's try to re-establish the Bluetooth connection between your tracker and your mobile:
That should get your Fitbit to start working correctly.
Please let me know how it goes.
04-13-2017 19:15
04-13-2017 19:15
04-14-2017 07:02
04-14-2017 07:02
My fitbit 2 was getting notifications and then nadda. It's syncing fine. I have the NOTE 4.
04-14-2017 07:17
04-14-2017 07:17
Hey @Nannabug!
Since you purchased it very recently, I would definitely consider that as an option. It is better to be safe than sorry.
If you do go with the seller, please keep me updated on what happens.
Let me know how it goes!
04-14-2017 09:18
04-14-2017 09:18
Hi @HDTRISH, welcome to the Community! 🙂 Let me give you a hand on this. First of all, make sure that the notifications are set to "ON" on your tracker itself, if so, please restart your Charge 2, if after that, your Fitbit still not getting notifications, please take a look at the instructions for Android devices in this post.
Give it a try and let me know how it goes!
04-14-2017 18:54
04-14-2017 18:54
04-16-2017 05:16
04-16-2017 05:16
So my notifications were muted. You rock thank you. My test notification worked ...lets keep our paws crossed it works today!
04-20-2017 08:40
04-20-2017 08:40
I have a Charge 2. And since my last fitbit update and Samsung update this week I am no longer receiving text/call notifications. I know about the mute button so it's not that. I uninstalled and reinstalled fit bit app and still no luck. I really count on this when at work. Can you please help?
04-20-2017 18:24
04-20-2017 18:24
04-20-2017 18:24
04-20-2017 18:24
05-01-2017 17:59
05-01-2017 17:59
Hi Lanuza, I took the Fitbit back to the store and swapped it for another Charge 2, same color and size.. This one does receive the phone and text notifications. Yay!!!!!! Thank you so much for your assistance.
05-25-2017 07:02
05-25-2017 07:02
I have a charge 2 and the S7, just bought it, I have looked for every option I can think of, it is not muted but I am no longer getting the vibrate alert on my fitbit from the phone that is next to me.
Bluetooth is on and paired, tests work but nothing for Calls or Whats app messages like I did on my old s5 any further ideas at all?
05-25-2017 19:10
05-25-2017 19:10
I have a different phone but discovered by accident that on my Charge 2 notifications can somehow get turned off. This might not be your problem but wouldn't hurt to check. When Charge 2 is on first screen, time/date/steps, if you press and [briefly] hold the button it shows Notifications On; but if you hold the button a too long it changes to Notifications Off. You may not even notice if you changed it but if you did you will not get notifications anymore. You may already have figured this out and it may not be your problem, but hopefully it might help someone.
06-17-2017 04:21
06-17-2017 04:21
Feel so dopey! That was exactly it! Thanks for the tip!!
06-19-2017 07:45
06-19-2017 07:45
Welcome to the Forums @Gregc63!
Glad to know that everything is in order now. You can continue to enjoy your Fitbit now.
If you have the chance, you should take a look at our Discussion boards. You can talk about a lot of different topics in there.
Hope to see you around!
07-24-2017 06:54
07-24-2017 06:54
Toggling this setting solved it for me. They had been set "On", but the toggle did it. All the other re-pairing options didn't seem to do anything.
07-24-2017
08:58
07:21
LanuzaFitbit
07-24-2017
08:58
07:21
LanuzaFitbit
Hi! Glad it worked out for you. Since so many people have experienced this
I don't feel so bad! 🙂
07-25-2017 08:45
07-25-2017 08:45
Welcome to the Forums @ronakshah2000! Hello @Nannabug.
Glad to know that everything is working correctly now.
Perhaps you could take a moment to visit one of our Discussion boards. You can find lots of different topics to discuss in there.
Hope to see you around.
12-17-2017 18:02
12-17-2017 18:02
This works for me, thank you~~~
