07-03-2018
05:05
08:17
AlejandraFitbit
07-03-2018
05:05
08:17
AlejandraFitbit
My Charge 2 will not sync to my S9.
Moderator edit: subject
07-04-2018
08:19
10:58
07-04-2018
08:19
10:58
It's great to see new faces @Anbru, welcome!
Keep in mind that in order to have a successful connection between your tracker and phone, it needs to be compatible. Have you checked if your phone is compatible? If you haven't, check the list here.
When a phone isn't compatible, it doesn't mean that it won't work with your tracker but you might experience some connectivity issues. You can always try the instructions provide in the help article Why won't my Fitbit device sync? but I don't guarantee it will work 100%.
Catch you later. ![]()
Best Answer07-04-2018 09:56
07-04-2018 09:56
Does this mean that those of us with newer Samsung phones are flat out of luck, or is a software upgrade in the works?
07-04-2018 10:27
07-04-2018 10:27
07-04-2018 13:48
07-04-2018 13:48
