01-25-2022 12:49 - last edited on 01-27-2022 10:17 by DavideFitbit
Hi,
My Charge 5 "forgets" that it can receive notifications.
Steps to reproduce:
1. install Fitbit app, sync Fitbit, etc.
2. set up notifications
3. notifs work fine for a few days
4. notifs suddenly stop coming through
5. go back to Fitbit setting screen, "notifications" option is missing from the Charge 5 settings menu (where it was before)
6. reinstall Fitbit app, and set up notifications again
Any ideas?
Moderator edit: format
01-27-2022 11:41
01-27-2022 11:41
This will happen after a logout in the fitbit app
01-27-2022 10:16 - edited 01-27-2022 10:17
Hi, welcome to the Fitbit Community forums, @lrklrk.
Thank you for sharing that you've been experiencing this inconvenience with your Charge 5.
That seems to be an odd behavior, if you're still having trouble with the app not showing you the Notification option, please try to:
In addition, please restart your device using the method described here below:
For other problems with notifications, follow all the steps listed here that have been useful for other users experiencing the same problem. Keep in mind that you need Android OS 8.0 or higher or Apple iOS 13 or higher on your phone and that you won’t see notifications on your Fitbit device if you turned on the Do Not disturb Icon or Sleep Mode.
Hope this helps, I'll be around.
01-27-2022 11:41
01-27-2022 11:41
01-29-2022 10:31 - last edited on 02-03-2022 06:20 by DavideFitbit
Hi Davide,
I have tried these steps in the past and it does not solve the problem. I am using a Google Pixel 6 phone running Android 12. Do you have additional suggestions?
Hi Rich,
This happens even if i do not log out of the fitbit app. Do you have further suggestions?
02-03-2022 06:19 - last edited on 04-03-2024 05:12 by MarreFitbit
@lrklrk Thank you for sharing this update and for confirming that you already tried all the troubleshooting steps suggested.
In this case, since you already tried all the recommendations shared in the forums and you continue to experience the same problem with the notification settings, I recommend that you get in touch with the Customer Support team for further assistance with this. They will let you know how to proceed.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
