05-05-2016 20:31
05-05-2016 20:31
Best Answer05-05-2016 22:33
05-06-2016 06:01
05-06-2016 06:01
Best Answer05-06-2016 06:02
05-06-2016 06:02
Best Answer05-06-2016 12:38
05-06-2016 12:38
Best Answer05-07-2016 08:57
05-07-2016 08:57
@EmilyMLA have you set up the device to work on your phone?
Do that first and you can see the version number of the firmware for your Fitbit. This isn't an update for the phone, but for the Fitbit.
Check out the article again, it's the first part - click
Time on your device will match what you set up on your cell phone.
Keep in touch.
Best Answer05-10-2016 14:50
05-10-2016 14:50
Best Answer05-12-2016 12:06
05-12-2016 12:06
OK, I finally was able to synch to my phone. Some of the steps that helped for me:
1) Adding the device to my laptop. In turn the device finally showed up in my fitbit app on my phone.
2) However, I still could not synch up to app on phone. It gave me the error "tracker not found".
3) I rebooted my phone and then was able to synch 🙂
4) However, when I tried to resynch it wouldn't work
5) I deleted a BUNCH of photos from my phone freeing up memory and now seems to be working with no issues.
It seems that Android phones do not have nearly as much storage as iPhones. A lot of my space is being taken up by "Miscellaneous files" that I don't even know how to get rid of. But happy to report I was finally able to synch with phone.
I think for future reference when people mention issues with Androids memory space should also be incldued as a potential issue.
05-12-2016 12:07
05-12-2016 12:07
And sorry, didn't say thanks for your help!
05-13-2016 22:27
05-13-2016 22:27
@EmilyMLA if you have an external sd card in the phone, you can move extra photos and such on there.
Go to your settings to Application Manager. Each app takes space. What I do is delete the cache - it doesn't hurt anything, but wiggles up more free space. Don't delete the data files, since that has your passwords and other pertinent information needed for certain apps.
Glad you got it to synch and thanks for the update.
Keep on stepping!
