07-16-2024 16:48
07-16-2024 16:48
It drives me nuts in the (Android) app that I can't click on a data point in the weight graph and see the value! This is especially annoying when I'm viewing my weight trend over many years (I've got >5 years of weight data) and I can't click and see what I weighed then. I'd have to manually scroll the log data back that far (if it's even possible) to see an exact observation for a particular date.
Make the top-level weight graph in the app interactive!
Best Answer07-17-2024 05:18
07-17-2024 05:18
Hi, @vq88 welcome to the community, may I suggest you take a closer look at the graph? Touch your weight tile in the "Today" screen of your Fitbit app>select a tab in the second row from the top of the screen>wait for the graph to populate with both weight & trend lines>place your finger firmly on the graph line and slide horizontally. You should now get an index line with a tile containing the weight & date, as you slide your finger the values will change. If you do not get the index line etc, lift your finger & repeat. I'm using a Pixel 8 pro, if you have another Android phone response to the screen touch may be quicker or slower.
I hope this helps, please post here again & let us know how you get on.
Cheers
Gr4ndp4 | UK
07-17-2024 05:18
07-17-2024 05:18
Cheers
Gr4ndp4 | UK
07-17-2024 14:42
07-17-2024 14:42
Amazing! Thank you!
