When I go to click on the weight tile i can slide through 4 screens
1. Weight trends
2. Lean vs fat
3. BMI
4. BodyFat %
All works well except Body fat%
It is Blank and the last data it shows is from 1/22/19
Also the Column next to weight in the list is all blank
And Nothing before that until Aug 2 2018 and then very random Days every 6 months or so for MAYBE a total of 6 days.
I also noticed it is not even available to see on the desktop version
What Am i missing here?
looking deeper at the app while on the weight tile if I click the + sign in upper left to add weight it says I have a fat% but that does not show anywhere else.
Now I am thinking I get food and weight into the App from a link With Map My Fitness and wonder if THAT is the issue
AND I notice i did not have a goal set for Fat% but set one now and will see if that helps
I just noticed it because I am digging deeper in my health metrics
And am linking up another device and just noticed it and would really like for this to work
Any help is appreciated
Samsung 9+
Fitbit Sense
Best AnswerBody fat % comes from smart scales that measure body fat, such as the Fitbit Aria 2 scale, or several other brands that measure body fat % the same way. Or if you have some other way of knowing or measuring your body fat, you can add it manually. But other than these, Fitbit has no way of knowing your body fat %, so it is blank.
