Hi there @QueenTia, nice to see you again, I was reading your tracker is not responding after the break. In this case I would recommend to try a restart:
If this is not addressing the issue, perhaps the tracker is not receiving charge. For this I would suggest to review the following:
Dust and debris can accumulate over time and prevent a charge. So clean the charging contacts on the back of your tracker to ensure they stay bronze or gold in color. You can use a toothpick or a toothbrush with rubbing alcohol. Make sure not to scrape the contacts with a wire brush or anything metal, since this can damage the plating and cause corrosion. If you use a toothbrush, dry with a cloth or tissue before charging.
Other caused is the USB port or outlet is faulty. So If you haven't done so, try a different port. A UL-certified wall charger will also work. Don't use a USB hub. You can review if the tracker isn't connected securely to the charging cable too.
See you around and hope this helps.
