04-18-2020
14:21
12:51
RicardoFitbit
04-18-2020
14:21
12:51
RicardoFitbit
Somehow my runs no longer show the map and split times in my (Android) app. Screenshot
If I recall it correctly, they showed when I did a test measurement run (but I unfortunately deleted that run).
Any idea how to be able to see my map and split times in my app? I don't know if this is a bug or somehow I changed one of the settings responsible for this.
When I click on my run, only heart rate, calories and active zoon minutes show in my app. GPS does seem to work as it measured the overall distance correctly.
Thanks!
Best Answer04-28-2020 12:50
04-28-2020 12:50
Hi @suite48, welcome to the Community Forums! Sorry for the delay in responding your post.
Thanks for bringing this to my attention and for the details that were shared in your post. To better assist you with this, can you please let me know which Android mobile device are you using? When was the first time you experienced this issue and how many times since then? If you haven't already done so, please try the following steps:
Keep me posted and let me know if you have any additional questions.
