02-20-2019 08:51
02-20-2019 08:51
Going to be away from iternet access for 1 month. I need to use my charge 3 with my androd fone.
How do I do it?
thanks,
Keith
Best Answer02-20-2019 09:53
02-20-2019 09:53
From What should I know about traveling with my Fitbit?,
"Summary data (calories, distance, steps, and floors) will be stored for 30 days. If your tracker measures heart rate, summary heart rate data will be stored as well."
So if you can at least keep your tracker charged, you should be able to keep at least 30 most recent days summary data, to sync when you do get internet access.
As described in Can I see real-time data in the Fitbit app?, you will be able to see some, but not all, data on the Android app directly via the bluetooth link, without actually syncing to the Fitbit cloud.
Best Answer02-20-2019 10:45
02-20-2019 10:45
Best Answer02-20-2019 10:55
02-20-2019 10:55
By "for extended periods", do you mean for longer than a month, or is that you need detailed rather than summary data, or do you mean that you won't have power to keep it charged?
Best Answer02-20-2019 16:50
02-20-2019 16:50
Best Answer02-20-2019 16:55
02-20-2019 16:55
I understand now. I was going by your original question about one month without internet access.
Best Answer02-20-2019 16:59
02-20-2019 16:59
