Hi all. I have just had a new phone come today and for some reason my blaze won't connect to it at all. I had no issues with my old phone (galaxy s5) Its just not connecting at all with my new phone (hawaii p10) any help would be appreciated.
Thank you
This could be a problem. Your S5 is on the list of supported devices at www.fitbit.com/devices but the P10 isn't.
Sometimes a phone that's not on list does work so hopefully another P10 owner will be able to confirm but there's not really a lot that can be done if it's not compatible.
Do you have access to a computer that you could use to sync rather than using your phone?
