03-27-2019 16:45
03-27-2019 16:45
I do yoga, HIIT, weight lifting, pilates, etc. I don't walk or run for exercise. I want to track my exercise but it seems all I can track is waking or running under the "track exercise" icon. What am I missing?
TIA
Best Answer03-27-2019 18:05
03-27-2019 18:05
Which tracker do you have?
Best Answer03-27-2019 20:41
03-27-2019 20:41
I believe @amberN_garcia is actually using the Fitbit app and not a tracker.
If this is the case the active tracking (meaning pressing the play button) enable only GPS activies (run, walk, hike).To input another activity (such as yoga) you need to do it only afterwards inserting your activity data as "log previous".
Best Answer03-28-2019 05:25
03-28-2019 05:25
Best Answer03-28-2019 05:26
03-28-2019 05:26
Best Answer03-28-2019 06:07
03-28-2019 06:07
With the Charge, the way to track exercise right from the tracker without phone, is just hold in the side button until you see the stopwatch start; then press it again to stop. The Charge does not allow you to differentiate the exercise type as you record it.
Best Answer03-28-2019 12:53
03-28-2019 12:53
