02-07-2023 23:27 - edited 02-07-2023 23:29
If you need a useful reminder on your watch to charge your phone you can get it with the following :
Using MacroDroid on your Android phone, which allows for 5 free macros, create one macro like this, and in the Fitbit App Device, Notifications, App notifications, select MacroDroid
The process is:
Open MacroDroid
Click Macros at the bottom
Click + at the bottom
In Triggers, click Battery level, and ok in the popup
Slide to the desired level and click ok
Repeat for as many levels as you need alerts for, then
Click Actions at the top
Click Display Notification
Enter title = Phone Battery
Enter Notification text ,as shown above
Click ok
Click tick and give the macro a name
That's it !
Each time the phone battery falls to a level you have selected in your macro you will receive a message on your watch, if it is Bluetooth connectible at that time.
Of course it can be used to alert you of other events with additional macros.
