07-08-2017
14:09
15:48
07-08-2017
14:09
15:48
Since the last update will no longer sync with a Samsung S4.
It may be to do with the upgrade or it may be just a random syncing problem.
Whatever the cause I would try restarting your phone and then restarting your fitbit using this procedure:
https://help.fitbit.com/articles/en_US/Help_article/1186/
Give this a few tries as it doesn't always work. If it still won't sync after that then there are some more ideas to try in this help file:
