01-05-2017 08:10
01-05-2017 08:10
I'd like to see my steps but I'd like to hide it from my challenge members.
Best Answer01-05-2017 09:11
01-05-2017 09:11
@Divanik, on the App, select Account, then select your device (Charge 2?), slide the All-Day Sync to the left so it is grayed out, then scroll down the screen and do the same with Always Connected. Scroll back up the screen and tap on Sync Now so that the update is sent to your tracker.
Best Answer01-05-2017 08:31
01-05-2017 08:31
@Divanik, if you turn off All Day Sync and Always Connected, your tracker will not sync until you manually sync it. You will be able to see your steps on your tracker, but you Dashboard will not be updated until you manually sync it.
Best Answer01-05-2017 09:06
01-05-2017 09:06
01-05-2017 09:11
Best Answer01-05-2017 09:23
01-05-2017 09:23
