06-26-2017
13:25
16:13
CarlosMo
06-26-2017
13:25
16:13
CarlosMo
Hi, has anyone else had issues with the Fitbit app on Galaxy Note 5 when trying to log a run with GPS? The timing is off by a good 2 minutes. I know my normal 1/2 mile time and since i just synced my Fitbit with my new phone, it's timing is way off. Any suggestions??
Modified by moderator: title for clarity.
06-29-2017 11:30
06-29-2017 11:30
Thanks for stepping into the Forums @diana250!
I'd like to ask you some question about the situation:
Look forward to your reply so that we can make sense of this.
06-29-2017 11:30
06-29-2017 11:30
04-05-2018 11:54
04-05-2018 11:54
Hi, I completely missed this post! But since my last post, I started using Runkeeper to track my runs instead of my Fitbit. But I recently had to replace my Fitbit Charge 2. I tried to use it to track a treadmill run and again, I encountered the same issue. The timing was really off. Any suggestions?
04-06-2018 06:19
04-06-2018 06:19
Hello @diana250.
Thanks for letting me know. Glad to know that Runkeeper has been working for you.
As for the treadmill, what exactly do you mean by the timing? Did it record it as if it started after it actualy started? How much after if that is the case?
Look forward to your reply so that I can better understand.
04-06-2018 06:39
04-06-2018 06:39
Good morning! It starts recording when I set it on my Fitbit to run but the timing just isn't accurate. I know my pace and after I ran for about 20 min, it said I ran 1.28. I should have been at the very least, 2 miles. I'm not sure why.
04-09-2018 05:51
04-09-2018 05:51
Hey @diana250.
Thanks for getting back to me with those details.
While you are on a the treadmill, are you holding the bars on the treadmill or are you running with your hands on your sides?
If you are holding the bars, then it would explain why the tracker is not properly recognizing the activity. It can't accurately feel all of your steps because you are holding.
