06-13-2018
01:57
07:40
RobertoME
06-13-2018
01:57
07:40
RobertoME
I have a Charge 2 and an Android phone running Android 8.1 with Fitbit App only recently installed.
I seem to several issues, which I suspect might be related.
What's going on, at the moment it is getting pretty tedious trying to use the functionality and having to delete all the extra workout sessions.
Tom
Moderator Edit: Updated Subject For Clarity.
Hi there @tomsimmons, good to see you are visiting the Fitbit Community. I owe you an apologie for the late response.
I saw your tracker is not syncing even when you have enable the option of All Day-Sync and Always Connected. for this I would recommend this help article: Why won't my Fitbit device sync?
If your tracker is having a hard time to find GPS signal or it drops the signal while you are doing your exercise, this other article will tell you the reason why this might be happening: Why isn't GPS working on my Fitbit device?
About the duplicate entry with no map, I have seen this behavior in a few scenarios, however there are no new details. Now this issue with the one you mentioned that is require and update I would like to recommend to reset the app.
Note that after the new update of the Fitbit app, the issue with restarting the notifications was addressed and should not continue happening.
So, logout from your Fitbit app and go to your phone settings. Access to the App manager option and look for the Fitbit app in your downloaded apps list. Once you are there, clear the app cache and data and proceed to "Force Stop" the app. (This may vary depending of the Android device and the OS version) Finish the workaround by restarting your phone. When your phone has initialized, go back to your app and try again.
See you around and If I got more information, I will let you know.
