03-08-2017 12:22
03-08-2017 12:22
Also, it won't automatically sync. I have to it the sync button or the item in the dashboard to get it to sync.
04-13-2017 12:30
04-13-2017 12:30
Hello @LindaLW!
Thank you very much for that update. The good part is that you'll be getting a replacement and will be able to keep on running towards your goals.
If you have the time, please visit one of our Discussion boards. There you can find a lot of different topics to talk about with the other members of the Community.
Hope to see you around.
03-09-2017 09:27
03-09-2017 09:27
I am not getting notifications either...
@SunsetRunner wrote:Also, it won't automatically sync. I have to it the sync button or the item in the dashboard to get it to sync.
03-09-2017 10:02
03-09-2017 10:02
A very warm welcome to the Community @SunsetRunner!
Have you tried turning the 'Always Connected' option on? Regularly it helps to improve the connectivity between the mobile and the Fitbit. To turn it on, please follow these steps:
That should help improve the syncing situation. Let me know how it goes!
03-09-2017 10:23
03-09-2017 10:23
03-13-2017 12:02
03-13-2017 12:02
Hello @SunsetRunner! Thanks for the clarification.
In that case, I'd recommend doing the following:
Keep me posted on how it goes!
03-23-2017 19:29
03-23-2017 19:29
Having the exact same issue. It worked fine for the first week, then quit working when I recharged it. When I removed it from my Samsung and rebooted, it doesn't show up as a device. I scanned again, and it was there. On a whim, I rescanned and it was gone. It hasn't showed up since. I think these things have a broken Bluetooth transmitter.
03-30-2017 13:32
03-30-2017 13:32
Hello @Mordigoff! Thanks for joining the Forums.
Did you try the steps I mentioned above? They should definitely help for situations like this. They have certainly helped me whenever I had any issues with the Bluetooth connection.
Additionally, have you tried syncing with any other device? That could give us more details on whether it is the tracker itself of the connection between the Charge 2 and your Samsung.
Look forward to helping you get back on track.
03-30-2017 14:19
03-30-2017 14:19
I also cannot connect my charge 2 to my huawei p9 phone tried all the steps .. reinstalling the app it just keeps failing
04-04-2017 04:34
04-04-2017 04:34
04-09-2017 14:00
04-09-2017 14:00
Hello @Joycmmorrison, welcome to the Community. Hey @Mordigoff!
@Joycmmorrison In this case, the Huawei P9 Lite is not currently a part of our supported devices list. Because of this, we are not able to fully guarantee that it will work correctly.
@Mordigoff Out of the other two Bluetooth devices that you mentioned, are they continuously connected to your phone? It could be that they are interfering with the connection between the Fitbit and the mobile. Perhaps we could try to turn them off and give the tracker a test once again.
Please do let me know how it goes if you try that.
04-09-2017 14:33
04-09-2017 14:33
Similar problem. My Charge HR has stopped syncing with my Samsung Galaxy 5S three times this week. I was able to get it back after multiple tries of all the suggestions here. Now it is saying Bluetooth connection issues. I unpaired it earlier, based upon a the suggestion above and now nothing. Extremely annoying. I've already spent way too much time on this!
04-11-2017 15:31
04-11-2017 15:31
Hello @LindaLW!
In this case, let's try to run the set up once again:
That should reestablish the connection between the two.
Please keep me posted on how it goes.
04-11-2017 16:31
04-11-2017 16:31
I tried that multiple times without success. By last night it was totally broken; only log 3000 steps after 1.5 hrs at the gym. I called Customer Service today and I'm getting a replacement. Thanks!
04-13-2017 12:30
04-13-2017 12:30
Hello @LindaLW!
06-16-2018 13:08
06-16-2018 13:08
This solution didn't work for me.
06-19-2018 09:18
06-19-2018 09:18
Hello @anniethorn!
Could you please go a bit more in-depth into what is it that you are experiencing? I'd like to help you out.
In the meantime, please follow the steps on this help article. Be sure to follow all of them in the order that they show up.
Please let me know if you have any further questions.
06-20-2018 15:52
06-20-2018 15:52
06-21-2018 08:45
06-21-2018 08:45
Hello @anniethorn.
Thanks for that clarification. Did you try to follow the steps I mentioned above? They should definitely help in this situation.
Additionally, I have a couple of questions:
Let me know if there is anything else I can help you with.
11-05-2019 18:20
11-05-2019 18:20
I keep having this issue as well for the past 3 weeks. I have done all of these steps multiple times. I have event contacted customer service with little help. Does anyone have any solutions that have worked?
11-23-2019 06:49
11-23-2019 06:49
Says it was solved, this is the best answer, but I do not see any fix in this best answer.
