@Beckbzmom Hi and Welcome - I have added a link that may help you with your enquiry
In order to set time zones, please: open the Fitbit App > tap the three lined button in the top left-hand corner > click settings on the pulldown > make sure that you have the correct time zone selected and make sure 'set automatically' is checked > force sync your tracker for changes to take effect. Hope this helps.
Kind Regards
Wayne
Best AnswerYour Welcome - if this has worked for you could you please mark as accepted so the thread can be seen as dealt with and no further action is required as a green tick will appear next to the enquiry - if this hasn't helped/solved your enquiry repost here that it didn't work and I will see if I can make other suggestions to assist you
Kind Regards
Wayne
