Nokia Body wifi scale
Has anyone been able to connect their Nokia Body scale to the Fitbit dashboard? I was hoping to automatically show the most recent weight from the Nokia heath app.
What don't kill U only make U smell stronger
4 REPLIES 4
@geekonabike It's great to see you in the Fitbit Community.
I'm happy to answer your question about syncing your Nokia Body scale to the Fitbit dashboard. Many users have had success syncing this scale to Fitbit. We were previously able to sync Withings scale to Fitbit, and now that Nokia took over the company you should be able to connect your Nokia Body scale to Fitbit through this link.
Hope this helps. Let me know how it goes.
Yes, I can say that the link works and I have The Nokia Body+ linked to my Fitbit account. The only thing I notice is that sometimes, there is a .1lb difference between the readings on the two apps... one Fitbit will say 145.6 and the Nokia app will say 145.7
Samsung Galaxy S8, Sense
@Buzzsaw It's great to see you around.
I'm glad to hear the link works, thanks for the update.
Keep on stepping.
I believe the issue I'm having is because the Nokia Body scale won't connect & the more expensive/more features Body+ scale does connect.
If you are looking a purchasing one of these go with the Body+ as beside connectability it also gives a body fat %, the Body only gives BMI.
