11-06-2019 04:09
11-06-2019 04:09
Hi
i get this message when i try to enable notifications.
Notification Service not running. A phone restart is required to Re-enable notifications on your tracker.
I have updated to the latest version of the android fitbit app on my phone. i have a blaze which is up to date.
I have tried re-starting, uninstall and re-install.
I'm using a Huawei on android 9.
any ideas?
cheers
dave
11-06-2019 06:54 - edited 11-06-2019 06:55
Here's what works for me in Android 9:
No restart of phone necessary.
03-25-2020 02:11
03-25-2020 02:11
Hi,
I am also using the same Honor phone. I will tell you how to fix notification service not running on Android. It's just one step.
Just go to Settings > Apps in your Android phone.
Find Fitbit app there and click it.
Then click clear data/storage for fitbit app.
Done.
Now you have to login to your fitbit app again and your notification service will be running.
Notification services will work definitely.
I have found this workaround after making a huge search hunt on the internet.
04-06-2020 05:25
04-06-2020 05:25
Thank you. This worked perfectly for me after setting up my Versa 2 on a new phone.
04-14-2022 13:47
04-14-2022 13:47
3 years later and this is the working solution. Thanks.
