11-24-2021
11:50
16:44
JuanFitbit
11-24-2021
11:50
16:44
JuanFitbit
Is there a way to change the three default water volumes in the "Quick Add" section for logging water? If not, can it be an option?
I frequently use three different volumes of water other than the default. I do not use the defaults nearly as much as I do with what I currently use which makes "Quick Adds" useless to me.
Thank You
@SunsetRunner , Nice to see you around. Thank you for your message and feedback.
At this time you can only log your water intake with the default volumes.
We're constantly striving to improve Fitbit products and services, and we appreciate all of the input we receive from our customers. The best place to make your voice heard is the Feature Suggestion board on our community (community.fitbit.com/t5/Feature-Requests/idb-p/features).
If a similar suggestion has already been made by another member of the community, you can vote for their suggestion and add your comments.
Thanks for your feedback and for participating in our community!
