05-06-2019
00:31
10:44
LanuzaFitbit
05-06-2019
00:31
10:44
LanuzaFitbit
It is possible to add past days water intake, past days weight - why on earth it is not possible to add past days quick calorie intake via app??? Where is the logic? I really do not wish to start logging each day food via this app. I use for logging my food myfitnesspal app. On my Fitbit Charge 3 I just like to see the in/out calorie balance, as it helps me regulate my daily food and exercise balance to reduce weight. Now I can add past days water intake and past days weight, if I havent done it daily, because I am really tired in the evening and fall asleep without adding information into my Fitbit app. For getting calorie balance in/out I must always add daily quick calories in the same day, in the evening, then I am really tired and can forget! Because now I can add the quick calories of the day for only today, not for yesterday, day before yesterday and so on (but for weight and water it works!!!). This is insane! Not logical to me, sorry.
Best Answer05-06-2019 10:53
05-06-2019 10:53
Welcome to the Forums @Marju.
Thanks for sharing your feedback on the matter and letting us know that you'd like to quick add to previous days.
At this moment it is possible to do so. When you are logging the food on the app it should give you an option to select the day that you are logging it into. Check the picture below for reference:
This should clarify the situation. Let me know if you have any further questions.
