Hello @LaurieLL you say that you bought the Inspire today, have you been able to attach it to your Fitbit account?
I also moved your post to it's own thread since it is easier to keep the thread to a single issue
Best AnswerAte you having a sync issue, or a notification issue?
When you say turned on, is it on the tracker or under the Inspire Settongs, Notification that it is turned on.
When I have notification issues, I usually disable notification under the 3 dots. Then when I re- enabled the app asks me to grant all kinds of permissions
