06-25-2017 13:35
06-25-2017 13:35
I would like to buy new silicone ring, because mine is broken. The problem is, that I can't find where I can buy one?
Ideas anybody?
Thanks.
Best Answer06-25-2017 17:59
06-25-2017 17:59
This is the android forum, what silicone ring are you referring to?
Fitbit will often send you out replacement bands if they break due to normal usage. Contact Fitbit Support.
Best Answer06-25-2017 22:19
06-25-2017 22:19
06-25-2017 22:19
What picture?
Best Answer06-25-2017 22:41
06-25-2017 22:41
