Best AnswerWelcome to the Fitbit Community @Derick1w! I have seen some instances where users are charging the device incorrectly; you should double check the charging instructions. Battery life is affected by various factors and settings. Take a look to the tips for preventing battery drain. If the issue persists, please be sure to reach out to our Support Team. I know that they're always happy to listen to your experience and provide different options for you, if needed!
I hope this helps. Let me know the outcome.
